Trick Flow Rockers - Torque & Compression
  • Thread starter Thread starter rpark
  • Start date Start date Jul 16, 2011
R
rpark
Central Ohio
Jul 16, 2011
  • Jul 16, 2011
I'm in the process of upgrading from stock heads to Trick Flow Twisted Wedge 185cc heads with 1.72 trick flow rockers.
According to trick flow's instructions, the rockers are supposed to be torqued to 55 ft lbs. Now I don't recall if that was the rocker studs or the nuts that hold the rockers on.
Anyway, if I torque the special nuts that hole the rockers in place to 55 ft lbs... I don't get any compression... hence no fire.... if I loosen the rockers up a lot, to say 20 ft lbs or less, then I get compression...
So my question is... what am I supposed to do? Loosen the rockers up until I get compression in each cylinder? Unfortunately, Trick flow's tech line is only open M-F, so I thought I'd check here.
Thanks
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Jul 16, 2011
  • Jul 16, 2011
I think that torque number is for the studs fastening into the head. I don't think you torque stud mounted rockers...I have pedestal mount rockers, and the torque for them is 18-20lbs.
Do an internet search for rocker arm adjustment. Its something like zero lash and then half a turn more...no torque.
Good luck.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jul 16, 2011
  • Jul 16, 2011
RangerJoe is correct, you're not supposed to torque the rockers. Find zero lash, by twisting the pushrod until you feel it start to slightly drag while turning the rocker nut by hand. Once you've found zero lash, turn it 1/2 - 3/4 turn and lock it down.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Jul 16, 2011
  • Jul 16, 2011
i believe those r the ones with the allen fastener in the middle.....find zro lash then i usually back out 1/8th, then tighten both nut and allen fastener 1/2 a turn
R
rpark
Central Ohio
Jul 17, 2011
  • Jul 17, 2011
Thanks to all. Surprisingly, the trick flow instructions are mute on this point. I'm starting to loosen up and find zero lash (a new concept for me). Thanks again.
Gregg@TFS
Premium Sponsor
Feb 11, 2008
53
  • Jul 22, 2011
Thanks
The rocker arm studs are what get torqued to 55 ft lbs.
See the document attached on how to adjust the valves.
  • Valve adjustment 101.doc
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jul 22, 2011
  • Jul 22, 2011
Sounds like a good way to break the poly lock.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 22, 2011
  • Jul 22, 2011
Be aware that Trick flow heads require a different push rod length to get the proper valve train geometry. You will need an adjustable push rod and a weak test valve spring to do the testing. This is because Trick Flow uses stud mounted rockers like the early 260/289/302 engines. The latter model engines use pedestal mounted rockers. There is much testing and measuring, but this is the short version of the process.
The following method is very messy, but it will work.
Remove both the valve covers (you may have to remove the EFI upper manifold. to get one side off).
If present, cover the pushrod squirt holes in the rockers with aluminum foil. This will reduce the amount of oil that is wildly squirting from the valve train. Start the engine and somehow get it to idle. Loosen each rocker adjuster until the valve/rocker rattles. Then slowly tighten it down until the rattle goes away, and tighten it 1/2- 3/4 turn more and lock the adjustment. Repeat the process until you have made a complete pass through all the valves. Recheck any that don't quieten down. When finished, you will have oil everywhere, and if you did right, the engine will not have any rattling rockers or valves. Shut the engine off and reinstall the rocker covers. Get a gallon of mineral spirits to bathe yourself and the car it to remove the oil that now coats everything you didn't hide or cover. Like I said, messy, but it works good.
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Engine Prw rockers, trick flow cam, gt40 heads
  • 67fox
  • Apr 15, 2024
2K
Fox 5.0 Mustang Tech Jan 15, 2025
hollywoodstang8
H
C
Fuel pressure help
  • clayton seiders
  • Aug 31, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 1, 2024
clayton seiders
C
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
M
Need help identifying trick flow heads
  • Muhchode
  • Mar 25, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 26, 2024
AeroCoupe
