Trickflow combo, will it work?
  • Thread starter Thread starter JMD Engineering
  • Start date Start date Aug 19, 2005
J
JMD Engineering
102
Northern VA
Aug 19, 2005
  • Aug 19, 2005
Well- i dont have enough money for a whole TrickFlow Street heat, so im planning on piecing the kit together over time.
This is what I'm planning on getting, but i wanted to get some advice on whether id have problems (with the intake/TB/Maf/injector combo):
- Street heat intake (upper/lower)
- 24#
- 73mm C&L MAF (calibrated for 24#)
- 70mm TB (too small? what brand?)
- MAC 5.0 CAI
- (if necessary?) EGR Spacer
Anyone see any problems with that combo? Im running a B303, Flowmasters, O/R BBK Xpipe, STOCK Headers (will get BBK's if money permits after), removed air silencer (heh). And finally- after it all, how much will i be putting out ?
Philstang
203
  • Aug 19, 2005
what heads?
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Aug 19, 2005
  • Aug 19, 2005
Leave out the CAI and put the money towards something that will actually make some power. Get the heads first and the MAF and injectors after...you should go with a pump upgrade now though. Use the money you saved from the above to do the exhaust. With above items less the heads the B cam will hurt more than help..you looking at 210 maybe at the wheels, injectors and TB won't help untill there needed..and there not needed without the increased flow from the heads.
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
C
Dyno day! # guesses?
  • clayton seiders
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2025
Scrapla347
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
  • dan50
  • Jul 18, 2026
dan50
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
