trickflow head combo, with supercharger
mattie600r
new england
hello people. im in the process of purchasing the trickflow head combo off of summit which comes withe pretty much everything including the cam. but my question is that i want to kno if this system is compatable wit a 331 with a vortech supercharger which is my plans to do with my stang, eventually. does the cam run good with a supercharger or should i just get the heads and focus on sumting a lil bit beta as for a cam and rockers...
and another question is that im also lookin to get a supercharger. but ive been lookin at the vortech v-1 and v-2 sq wat is the difference and reliable between them 2?
thanks..
matt
I ran this kit with a Vortech A-trim using a UPR boostmaster pipe, Pro m calibrated for supercharger and 30's, 7" crank pulley and stock pulley on blower. 75mm throttle body and full 2-1\2"exhaust with 1-5\8" shorty headers and made 390 rwhp at 5# of boost. I am currently running a similar Combo with the exception of Track heat intake and V2-SQ
and no pipe. I think the stage one cam is OK with forced induction but I would think a custom cam would be a great way to go to get the most out of it.
v1 is the regular compressor (loud)
v2 is the SQ (super quiet) and its quieter
the SC trim is an s trim with different gearing than the regular S and makes less boost out of the box but the blower itself flows 1000cfm just like the s trim, you have to spin the SC faster to get the boost the s trim makes. IIRC the SC trim only comes in V1 styles
the s trim makes 8-10 out of the box, this comes in v1 and v2 models.
and a blower would work great with the TFS stuff, BUT i would ditch the stage 1 cam and get a custom cam, will make more power that way.
V2 has a larger step up ratio and my understanding is more efficient than the V1. It is quieter but can still be heard. According to the Vortech website the sc is available in the V2 gearing however probably not in kit form
I bolted on the Procharger, 10psi of boost, after running my TFS street heat set up for to years. Runs fine, but a Track heat upper, and a custom cam, may be a stronger setup. ( I have max flywheel hp at 5500rpm )
It all depends of what you gonna do, race, or daily driver.
My setup is nice to drive in any situation, and it feels really strong.
AND, my old -86 block works well at only 5.600rpm :)
Good luck with it.
FLYWHEEL HP:
