I have an 89 lx 5.0 and at idle the trickflow intake seams to be whistling rather loudly. Ive sprayed starter fluid throughout the engine compartment ot detect a leak and i found nothing. Is this just how this intake is or do I have a leak?
My issue was that when I put my TPS back on it broke. This caused the IAC to try to compensate for the unknown throttle position, which caused a loud whistle.
It was the air moving past the IAC that caused the noise. So check to see if your getting .7-1.0 volts on your TPS AND LET US KNOW
NicwoaC- is that defect in the picture a hole that i am supposed to grind down? ir is it a piece thats sticking up? if its a hole, how do i grind it down? just make it flush? thanks!
