trickflow R intake too much?????
diponyou50
138
11
well i have the opportunnity to pick up a trickflow r series upper and lower in good cond and an accufab 75mm tb for a really good price.
is this combo too big for my motor?
if so can you explain?
thanks im going to be purchasing this tonight if all goes as planned.
heres the part number TFS-51500003
I would get it, if it is a good price definitely get it. If it's the box intake you may lose too much low end torque for anyones liking, but the normal intake with runners should be fine. Granted it will be a little big for your setup but I think you should still notice a gain and set yourself up for the future. You can also probably make some of your money back by selling your old cobra intake.
thanks for the input guys.
im going to pass on the intake and tb:nonono:
and im going to have a guy port my cobra intake and then just get a 75mm pro-m.
or would you recommend something else:shrug:
well i just talked to the guy and he said that part number he just grabbed off summite to give ppl a reference its actually "track heat tfs sbf efi 2u"
thats what it says on the upper manifold.and ive been looking up that part number and the only thing that comes up is the track heat manifold.
im going to keep searching.anybody have a "r" manifold on hand to double check???
__________________
If it's already done, then it's too late, but a Cobra intake is better than the track heat for the combination you currently have, IMO. Track heat is not going to make the kind of power down low that the cobra will. Porting the lower Cobra will yield some decent returns. The problem with the Track Heat, and especially the R, is that they're focused on higher RPM and in the R's case more cubes. I don't think you'll notice much of a difference on a stock Cobra, and I think you'd notice a loss of performance vs. a ported-lower Cobra. But, good luck.
Chris
