Trickflow Track results
mackey
1,284
Beverly, Massachusetts
Combo:
1994 Mustang GT
Trickflow H/C/I (stage 1 cam/street intake)
24# inj
pro-m 80mm
FRPP 3.73s
No suspension work
Stock Tires
Stock TB
If there is anything else not on the list it is stock.
Shifter etc.
The track results were a 2.15 60' with an ending time of 13.4 @104.5. I think it is pretty good with street tires and stock throttle body. I was also shifting really slow because I didn't want to break anything. The weather was also not in our favor because the temperature was around 80* and the humidity was so high! It actually rained about an hour after I left.
I ended up after getting 3 runs in about 1.5hours because I believe my throwout bearing seized. Oh well there is always next time.
1994 GT
Never been tuned. 110k Shortblock
1/2 tank of gas
So 2.15 60'
1/4 mile 13.4 @104.5
If I get some decent tires and can pull off 1.7 60's it would be around a 12.6. With the new throttlebody it should definitely pick up some over the small stock one. By the way the only weight reduction in my 94 is the aluminum heads and no A/C.
I am VERY pleased with the results and hopefully by the end of the season should be seeing mid 12s.
Guyfoxbody said:
Dude, you spent all that money and didn't update the TB? With that combo, you should easily see low 12's with sticky rubber.
Yea stupid huh? I seemed to do everything backwards. I did the H/C/I before the gears also. Ran a 14.3. I can't wait to get this thing back running again. TB is next mod, then DRs. Of course after I fix the TOB.
Any other mods, like exhaust, roller rockers, injectors, etc. done to the car? Those times are great, and give me some hope. With the mods in my sig, I could only get to 13.951 in the 1/4. I threw in a stage 1 cam and am getting the lower intake ported and 3:73 gears. Also looking for 12's.
Yes I forgot to mention I have shorty headers (MAC), Prochamber and the american thunder catback. 24# injetcors. Roller rockers came with the kit. (trickflow).
Steven, get some drag radials and you'll see a huge improvement. Your mph should jump too from the better hook. Whats your timing at? Did you play with fuel/timing at the track? Drag radials, 75mm tb and tuning are what you need to do :cool: I ran a 13.8 @ 102 my first time out with my TFS combo (first time ever at the track) and after working out a LOT of bugs, I managed a 12.8 @ 107 shifting about 400 rpm's too early. That was with shorty headers and a small 65mm tb. Car dynoed 304hp/339tq.
I don't have an adjustable fuel pressure regulator. Timing was up to 16*. I'm going to go higher next time.
