So I know there where some replys but I didn't get to read them all b4 the server crash. So if guys don't mind posting your opinions again that would be cool. I'll post below the replys that I have saved in my email
Hey guys,
Well I have read a lot of post from the past, and I am trying to figure out what combo to run. My friend is building a 351W for his 69 mustang and wants to have 400 RWHP when he is done. He plans to run this motor NA and carbed, it is a 4 speed with a 3.80 rear in it. Anyway, the bottom end of this motor is going to be a fresh rebuild, but it will be stock. I read a lot of post and people were suggesting to use either TFS-R heads, Vic Jr or AFR. Right now I am leaning toward AFR for a few reasons. I like the TFS-R, but he has a set of Hooker headers already and it looks as if he will need to get custom headers to make it work. The Vic Jr head bother me, because the RPM range was in the 3000-8000 and since this is a stock bottom end I don't think it will go past 6500 RPM. So that left me with AFR, I like the 205 outlaw race head found here http://www.jegs.com/cgi-bin/ncommer...623&prmenbr=361
But I think it is a little out of his price range, so to get to my question how about the AFR 185 outlaw head found here http://www.jegs.com/cgi-bin/ncommer...623&prmenbr=361
What would be a good intake and cam also. He has a new RPM air gap intake, but I think he might need to step up to a Vic jr intake.
Anyhow what type of #s can we expect at the wheels with the AFR 185, vic Jr and a hydrolic split pattern cam around 23x / 24x @ .050 with 112 LSA.
I could be way off with this setup so let me know how to get to that goal of 400 at the wheels if it is possible with the stock bottom end. I am kinda worried trying to do it NA, because most of the parts are gona need to rev high.
Thanks,
Mario
[QUOTE='69Stang]750 Holley, AFR 185's, roller rockers, 10.5:1 compression or more but < 11.0:1, Victor Jr. intake. I would get a solid roller cam with high 230's duration @ .050, .580ish lift on a 110 LSA. Hooker Super Comp Headers with a 2 ½" or 3" exhaust. 6 Quart oil pan and windage tray. Electronic ignition with an MSD 6AL. Aluminum pulleys. Shift at 6500 RPM's. You could go with a bigger cam if you don't mind low vacuum and a grumpy, stinky idle. [/QUOTE]
Hey guys,
Thanks,
Mario
bluevenom867 said:I would use the Victor Jr. heads,the intake specifise the rpm range.On my 357,I ran a set of TFS track heat heads with a a clean up on the intake and exhaust,and was probably close to 400-425hp with the Victor Jr. intake,750 Speed Demon carb,and a TFS Stage 2 spec cam (it was a Crane grind,but same specs).
bluevenom867 said:My motor just had some 10.5:1 KB hyperutectic pistons,but ran fine with a 150 shot.
