Trying to pick out a clutch
LarsD
2,680
119
123
Texas
My new engine is supposed to ship next week. So I am running through my parts lists to make sure I haven't missed anything.
I'm down to these:
SPEC:
SF482T MUSTANG SPEC 26 SPLINE TKO/G-FORCE STAGE 2 CLUTCH KIT 10.5"
RAM:
RAM Automotive 98794T - RAM Powergrip Clutch Kits - Overview - SummitRacing.com
RAM HD:
RAM Powergrip HD Clutch - 26 Spline (86-Mid 01 Mustang GT and 93-98 Cobra) at AmericanMuscle.com - Free Shipping!
Zoom (I really want this one as my 89 had a Zoom and I loved that clutch, but it won't ship until the 25th if I order it now):
Zoom Performance Products HP48-1S - Zoom High Performance Clutch Kits - Overview - SummitRacing.com
I'm limited in my clutch selection since I have a 26 spline TKO as opposed to the more common 10 spline. Anybody have any experience with any of these clutches?
Thanks
I'm not sure if i've driven a Ram or Ram HD, but a buddy's car has a Ram clutch and it's awesome...it held up great behind his ~450hp stroker and the pedal effort was very reasonable...WAY lighter than my King Cobra but stiffer than stock.
LarsD, The Ram powergrip HD you posted from our site kicks-ass!
It will hold all the 400whp launches you can throw at it, but since it is a full-face clutch, it will not turn your left leg into a body-builder's.
The good news is that it is in stock and ready to ship. If you ordered today, you would have it in Texas either Thursday or at the latest Monday!
I hope this helps, good luck on the build!
What is your intended purpose for the car? Street/strip, Street only or Strip only?
How much time will you spend in traffic as a daily driver?
Are there any memebers of you family that will also be driving the car on a regular basis?
A 10.5" Chevy disk comes with a 26 spline hub and can be used without modification with any of the 5.0 Fox pressure plates.
I know what clutch not to get because I hated is so much, Spec Stage III (Luckily my car wasn't a DD at the time). Best clutch for an NA 302 I had was a simple FRPP King Cobra HD (love the light pedal), I think we have a Pro Motion one on the Pro Motion T-5. Pedal is engaging right of the floor so I picked up a UPR quadrant and firewall adjuster which I got in the mail today. It needs adjusting. Never had a ZOOM.
I'm waiting to find out if the flywheel I'm getting with the engine is compatible with that clutch or not. I already have a bunch of parts sitting in my cart waiting to be ordered from you guys for this build.
98% street. I do go to the strip, but not very often. I'll be the only one driving it, but I do spend a bunch of time in traffic.
The powergrip is a great clutch. I also bought thier zero balance billet flywheel and it was within like 5 grams of being balanced with the clutch attached to it
I believe this is the one I am getting with the engine, still waiting for the builder to confirm:
Ford Racing M-6375-A302B - Ford Racing Flywheels - Overview - SummitRacing.com
I do plan to run the car occasionally with drag radials if it matters.
If your're looking at 400 flywheel & running on drag radials, the Ram Powergrip would be a perfect fit.
The RAM 98794HDT Powergrip HD is an aggressive clutch that will exhibit chatter on takeoff as it has 900 series sintered iron "pucks" on both the pressure plate & flywheel side. While it will handle just about anything you can throw at it, it may be a bit overkill for your primarily street driven application.
The RAM 98794T Powergrip has the 900 series sintered iron "pucks" on the flywheel side & 300 series steel backed organic lining on the pressure plate side. It still holds up to 500hp & the amount of chatter is significantly reduced. It acts more like a street clutch, but maintains the holding capacity of a more aggressive one.
With either one of these clutch sets, a billet steel flywheel is strongly recommended as a cast iron flywheel will wear in a wavy pattern causing all kinds of chatter & engagement issues down the road.
Would this clutch be OK with drag radials also?
