tune up
  • Thread starter Thread starter GT89Mustang
  • Start date Start date Jun 18, 2005
G
GT89Mustang
Monmouth County, NJ
Jun 18, 2005
  • Jun 18, 2005
Kinda a newbie question but oh well...
Going to do a tune up in the next day or two, any preferred brands for plugs, cap, rotor and wires? Car is basically stock except for exhaust. Also might do an oil change, recommended filter? How many quarts am I going to need? Dumb questions but gotta learn somehow
stang22
1,318
Washington, D.C.
Jun 18, 2005
  • Jun 18, 2005
Autolite 25's for your plugs.
I have always had good luck with Well's caps and rotors for Autozone.
Ford Racing plug wires or Accel. 8mm or 9mm.
5 quarts of oil.
Don't forget to change your fuel filter as well.
Tim
txstang84
1,639
42
69
Tuscola, tx
Jun 18, 2005
  • Jun 18, 2005
5 quarts of oil.
Tim
x2
txstang84
1,639
42
69
Tuscola, tx
Jun 18, 2005
  • Jun 18, 2005
as far as filter, go with motorcraft, purolator, k&n, mobil-but whatever you do-NO FRAM OR QUAKER STATE
M
Mark89coupe
206
  • Jun 18, 2005
I use Ford stuff. No problems.
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jun 18, 2005
  • Jun 18, 2005
as mentioned before... keep the quaker state oooout
G
GT89Mustang
Monmouth County, NJ
Jun 18, 2005
  • Jun 18, 2005
A couple minor questions, whats the difference between 8 and 9 mm wires?
K&N sells a oil filter thats like 5 bux more then the others, is there really any benefit to it?
The filter thats on the car now looks like the plastic casing melted a little from the headers, are there any filters that resist heat?
Finally, is there any special tool needed to replace the fuel filter?
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jun 18, 2005
  • Jun 18, 2005
For the oil filter, Motorcraft FL1A is the best. The same thing as PureOne, but with the ford lable and half the price.
Autolite 25 plugs (no platnum junk)
I would go for a FRPP Cap and Rotor kit, also comes with the plastic base to the distributer. The FRPP 9mm plug wires are not only high quality, but perfectly lengthed and numbered. The fuel filter doesn't require any specail tools. A flathead screwdriver that's it.
Be sure the throttle body is clean on the inside. I found spraying about a can of carb spray down the intake with the engine running holding the throttle open before the tune up cleans out the induction. I would also take off the IAC and clean it out as well as spray the opening while cleaning the rest of the induction. Set the TPS at .99V, and set the timing at 12-14* and your set.
txstang84
1,639
42
69
Tuscola, tx
Jun 19, 2005
  • Jun 19, 2005
outstanding advice-great tune up here you come!
stang22
1,318
Washington, D.C.
Jun 19, 2005
#10
  • Jun 19, 2005
  • #10
Now would be good time to give er some good ole Sea Foam too...
Tim
DW5.0L
172
Florida
Jun 19, 2005
#11
  • Jun 19, 2005
  • #11
Replace your PCV valve and get a new air filter too, unless you have a K&N.
SeaFoam is an awesome product.
04sleeper
2,674
14
89
Dallas, TX
Jun 19, 2005
#12
  • Jun 19, 2005
  • #12
Autolite 24's, Taylor wires (Better than the Fords with smaller 1 peice silicone boots, same price), Brass cap and rotor.
K
Kerpal
400
#13
  • Jun 20, 2005
  • #13
Here's what I did for my tune up:
Autolite 25 plugs
Taylor Spiro Pro wires (liking these a lot... the boots are easy to get a grip on & they seem very well put together)
MSD cap & rotor
Motorcraft PCV valve, screen and grommet + clear hose
Motorcraft fuel filter
Purolator PureOne or Premium Plus oil filter
K&N air filter
Seafoam through vaccum hose
Cleaned IAC with throttle body cleaner
the car runs much better, now I just need to bump up my timing a little and check my TPS voltage...
MahFiVeOh
531
9
49
Ontario, Canada
Jun 20, 2005
#14
  • Jun 20, 2005
  • #14
I dont mean to jack this thread but how do you go about cleaning the throttle body? Is it just a matter of removing the rubber inlet tube? Then spraying the cleaner into it? Just wondering because mine (the circle plate inside) has a bunch of crap on it (edges mostly and that small hole in it)
HISSIN50
34
129
Jun 20, 2005
#15
  • Jun 20, 2005
  • #15
http://www.muscularmustangs.com/tb.php
Your method works when it is not real dirty (i clean them like that as preventative maintenance before oil changes, etc).
Jason might have a different opinion about it. (Jason, congrats on the promotion. )
Good luck.
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • Locked
Engine Help timing possibly
  • K1tha1
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
P
Progress Thread New To Me 1988 GT - trying to set up vacuum lines for upper intake question
  • pindude80
  • May 6, 2025
  • 9 10 11
16K
Fox 5.0 Mustang Tech Mar 28, 2026
pindude80
P
