Tuners. E7's + Forced Induction 87 Vs 93 Octane
Interesting read. All I know about in my expierience has been my cars always ran better with 93 oct and about 14-15* adv timing (n/a) or 10* with nitrous. I used to 50/50 mix 93/100 and bumped timing to 12* and a 150 shot(ran the best times ever with this). With your iron heads detonation is more likely than with alum heads. I don't know what your timing is/should be but I'd be reading the plugs routinely. As a rule of thumb I'd run the 93 as a safety factor even if it doesn't "make more power".
Reactions: 90lxwhite
Risking cheap gas in a supercharged fox would be insane (IMO).
It's risk reward, cheap gas will save you a couple hundred bucks a year max, but a blown head gasket could cost thousands.
There is no fancy electronics on a fox to protect you from blowing it up like new cars have.
I bet if you went and put some 87 in it right now, put your foot to floor, it would ping (assuming the car isn't so loud you can't hear it).
