Tuning Hardware
  • Thread starter Thread starter Micheal Nadeau
  • Start date Start date Oct 24, 2014
Micheal Nadeau
258
32
49
Savannah, GA
Oct 24, 2014
  • Oct 24, 2014
In the OBD II world, we have J2534 box that allows for inter communication between an PCM and a laptop. I can change settings and flash the PCM in as little as 10 minutes.What do you need for an OBD I system? I'm not to clear on what I actually need. I want to be able to remove the EGR provision and lean the car out some. Not looking for anything crazy. Doesn't need to be on the fly adjustable or anything like that. I want to be able to make what ever adjustments I need, and forget about it. I have been on Moates site and have seen several different things on there, again not looking for anything over the top. Also not looking for something I am going to have to take to some one else. I want to take care of it myself.
Admin Dude
Jan 4, 1985
43,578
21,742
234
Box behind Walmart
Oct 25, 2014
  • Oct 25, 2014
You may be opening a can of unforeseen circumstances.
The answer to your question first:
The MOATs is an option, so are the TwEECer and TwEECer RT. These require 3rd party software to really make effective and it's still a pain in the ass.
More money but simpler to use would be the Anderson PMS.
All of these systems can be used to completely tune the car but if that is your eventual intention, you'll need more equipment than just the tuner. If all you're looking to do is adjust some sensors etc, then I'd probably opt for thee cheapest option (TwEECer) and use it for that. To be clear on one point... you can NOT flash an OBD1 computer. Whatever you end up with will need to be premanently installed. You can't flash and remove like you can with OBD2.
Micheal Nadeau
258
32
49
Savannah, GA
Oct 26, 2014
  • Oct 26, 2014
So I will be flashing and installing a chip to overide the PCM?
Admin Dude
Jan 4, 1985
43,578
21,742
234
Box behind Walmart
Oct 26, 2014
  • Oct 26, 2014
There are stand-alone systems but I don't think that's what you want.
What the chips give you the options to do are:
1. Make +/- changes to existing tables to include turning sensors and solenoids on/off (this includes varying the air meter tables).
2. Tell the adaptive controls of the EEC to 'stand-down' and run a replacement set of tables.
3. Store 1 or more tunes that be switched between and/or resume normal EEC control (OFF mode).
One of the fundamental differences between OBD1 and modern OBD2 is that the OBD1 tunes are hardwired from the factory. Their programs are in Programmable Only Memory and once the chip is removed, the EEC is once again normal. OBD2 has flash memory to hold the tune. That tune can be rewritten.
D
Need help for my PCM Mach1
  • Danaololo
  • Jul 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 30, 2025
Danaololo
D
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
R
PCM problem
  • Rjchild9
  • Sep 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2025
Rjchild9
R
