Expired Turbo '03 Ford Mustang
BII1990
Up for sale is one amazing machine. It's a stroked and turbocharged 2003 Ford Mustang GT.
Car includes the following mods:
4.6 Liter Stroked to a 5.1 Liter
Eagle Crank,
Eagle H Beam Rods
Airies Pistons
Hellfire ring set
DSS Aluminum main support
Trickflow 185 trackheat cnc'd heads with 150# springs
Custom Comp Cams
Comp Cam Adjustable Cam Gears
Trickflow Timing Chains, Tensioners and Adjustable Crank Gears
Canton Oil Pan
Victor Jr EFI Intake Elbow w/ 90 mm throttle body
80 lb Injectors
MSD coil on plug coils
BBK headers w/ an On3Performance Rear Facing Turbo Kit
76 mm ceramic ball bearing turbo
Tial Blow Off Valve and Wastegate
T56 Magnum Transmission Conversion
Spec Stage 5 Single Disc Clutch
8.8 with 35 spline gun drilled Moser axles
Light weight spool w/ 3.55 Gear
Drag "Style" Rear Anti-Roll Bar
Adjustable Rear Upper Control Arms
Rear Axle Narrowed 5 inches
Weld RTS rear wheels with 295/50/15 Mickey Thompson ET Street Radials
Front has complete tubular suspension with coil overs
Adjustable Caster/Cambler plates
Weld Alumastar front wheels
Drilled and slotted rotors
Magnafuel 750 pump with -10 AN supply and -8 AN return
A1000 fuel regulator
Sump added to fuel tank
Fuel gauge still works
Still has A/C, even with turbo kit.
Car turns heads absolutely everywhere. Come take a look for yourself......email, call, text....(217) four-nine-four-7790.
