turbo helpp!!
  • Thread starter Thread starter austin86gt
  • Start date Start date May 17, 2011
A
austin86gt
  • May 17, 2011
k so i got an 86' fox body with a 306 all aftermarket roller/rocker arms, rods, pistons, F303 cam, Trick Flow Twisted Wedge heads, 24lb injectors, Trick Flow upper/lower intake, larger throttle body 75mm, c&l 76mm maf, 190Lph fuel pump, and an adjustable fuel pressure regulator. ive been looking at various turbo kits and im not quite sure what one would be good for a moderate hp but still very well a daily driver. if anyone has some tips id like to know. thanks
faststang90
522
baytown texas
May 17, 2011
  • May 17, 2011
with a stock block puts u on a safe 450-500 hp build. they sell alot of cheap kits off ebay but i would not get one from them.
Cartech Complete Street Sleeper Turbo Kit: 87-93 Ford 5.0L Mustang & Cobra (air/air intercooled)
9
90stang5speed
582
Columbus Ga
May 17, 2011
  • May 17, 2011
Im no expert at this but, I think you are going to need more fuel. You could up the pressure but, I would think 24's & a 150 pump is going to be to small. I would get a wide band O2 sensor so you can keep an eye on AFR. boosted cars need to be richer at WOT. between 11.5 to 12.5
Black1987
my wife Bedazzled my input shaft
1,064
595
174
NC
May 17, 2011
  • May 17, 2011
I agree with 90stang5speed, you'll need a 255lph fuel pump and at least 42lbs injectors (36lbs will get you by). I don't see you out growing 42lbs on a stock block. A fuel pressure regulator with a boost reference and a blow through maf. Also, don’t skimp on a good tune and a wideband (LC-1 or AEM).
Check out On3 Performance, B&G, and Ponydown for some decent priced kits. Good Luck!
H
turbo advice
  • hawkinsdrag
  • May 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2025
hoopty5.0
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
C
331 build power expectations?
  • clayton seiders
  • Sep 5, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 7, 2023
FastDriver
C
Fuel pressure help
  • clayton seiders
  • Aug 31, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 1, 2024
clayton seiders
C
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
