Turbo question
  • Thread starter Thread starter Georgie
  • Start date Start date Jan 3, 2007
Georgie
455
Montreal, Canada
Jan 3, 2007
  • Jan 3, 2007
I'm looking into Hellion Power systems or Vecco High Performance kit..
the vecco is twin turbo..but the turbos are water cooled..what are the differences in water and oil cooled turbos?? which are better and more dependable?
http://www.vecco.com/mustang_kits.htm
http://www.hellionpowersystems.com/kit_86_93.php
I'm really interested in Hellion. I hear tones of great things about the kits and the quality! i cant say that for the vecco kits tho, but they r very interesting as well!
thanks
71swing
199
Omaha,NE
Jan 3, 2007
  • Jan 3, 2007
If they are water cooled this means they are ball bearing turbos. they will have both oil and water lines ran to them.
Ball bearing turbo are better than a normal turbo, but not needed. People do not normal going this route because they come with a little higher price tag.
I'm in the process of a turbo build and will be runnig a percision ball bearing turbo.http://www.fullboogie.net/files/13673695.html
Ballbearing will be alot easier to turn and will even have a little less turbo lag than a typical setup. The torgue response may come on sooner, like 500 rpm fast than a standard turbo.
plus they are way cool when you turn off the car and all you hear is the turbo still spinning for five min.
never heard of the vecco kit. But the Hellion kit is a very good qaulity.
Georgie
455
Montreal, Canada
Jan 3, 2007
  • Jan 3, 2007
thast funny..the vecco kits r cheaper than the hellion and the come with two water/oil cooled turbos vs the helion comming with one oil cooled..
71swing
199
Omaha,NE
Jan 3, 2007
  • Jan 3, 2007
That is why you should do all the research you can and find the best kit for you.
I have never heard a problem with Hellion turbo kits, and they have kits in stock.
It will be at your door that week, but most have a waiting list because they biuld as needed.
If you haven't, you shoukld check out www.turbomustangs.com This furom will cover all you need to know.
They also have a review section on turbo companies from people who already own the kits, There are a few about vecco and they don't come off in a good way.
here is a link to the turbo company review section on the forums.http://www.turbomustangs.com/smf/index.php?board=10.0
tording
164
Hampton, VA
Jan 3, 2007
  • Jan 3, 2007
I would go with the hellion system. I have never heard a bad thing about the hellion kits or the customer service. I have found that usually if something is cheaper in price and it comes with more items in the kit that there is a reason for that. Usually the items are not good quality or the kit does not fit quite right. I would go with the proven kit that gets good marks time and time again.
Georgie
455
Montreal, Canada
Jan 4, 2007
  • Jan 4, 2007
so would I...but i still need some explanations about water cooled turbos...
millhouse
1,985
Simpsonville, SC
Jan 4, 2007
  • Jan 4, 2007
Not all ball bearing turbo's are water cooled…and not all standard bearing turbo's are oil cooled. They come in many flavors. The "lag" difference between the two (ball bearing and standard) are not nearly as pronounced as what 71swing claims. Ball bearing turbo's do not coke up the way a standard turbo does…and for this reason cool down times are not nearly as crucial. In your typical non water cooled turbo setup (which 95% of us run) the standard turbo requires a cool down time to prevent hot oil from coking the bearing and shaft. What this means is that when you want to shut the car off….stay out of boost for about 5 minutes before hand to allow the turbo center section to cool a bit. Now…with a ball bearing setup the turbo continues to spin a bit after you shut down…which drastically helps with coking.
millhouse
1,985
Simpsonville, SC
Jan 4, 2007
  • Jan 4, 2007
To add with your last question…water cooled tubo's are not required. In fact, a majority of 5.0 setups are non watercooled for several reasons. In factory turbo'd cars, convenience, longevity, warranty issues etc. are all major factors. When people want to shut their car off…they'll shut their car off. Turbo's are usually shoved way down in the engine compartment for packaging reasons and are prone to major heat soak issues. This is where the longevity and warranty come into play. For these reasons (among others) a majority of factory turbo's are watercooled. Hell…many factory setups continue to pump water through the turbo after the vehicle is shut off. Again…anti coking and heatsoak issues are major factors.
Now…in your typical 5.0L mustang the turbo's are usually out in free air. Their not tightly packaged (better heat dissapation)…and most turbo guys have no problem taking slight precautions to prevent coking of their turbo's.
bubba-dough
1,044
Indiana
Jan 4, 2007
  • Jan 4, 2007
http://www.proturbokits.com/pages.asp?pid=2 Check out these guys. They do alot of NMRA cars. Just a glimpse of some of their customers are on the right side of the page.
Personally I would go with either Urist or Pro Turbo.
seijirou
2,417
DFW
Jan 4, 2007
#10
  • Jan 4, 2007
  • #10
Turbo timer
millhouse
1,985
Simpsonville, SC
Jan 4, 2007
#11
  • Jan 4, 2007
  • #11
seijirou said:
Turbo timer
Now how could I forget! Oh yeah…because I'm to cheap to buy the parts to rig it up!
seijirou
2,417
DFW
Jan 4, 2007
#12
  • Jan 4, 2007
  • #12
I'm all about cheap!
Georgie
455
Montreal, Canada
Jan 4, 2007
#13
  • Jan 4, 2007
  • #13
ok cool..thats what i was going to mention... can i use different boost controlers than what is offered in most kits...cuz the boost controlers that r used in *** cars are really nice units..hks,blitz, apexi
millhouse
1,985
Simpsonville, SC
Jan 4, 2007
#14
  • Jan 4, 2007
  • #14
Most manufacturer's don’t offer boost controllers wither their kit's anyways…so as long as it's compatible with the wastegate setup you have it's fine.
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
SN95 The Unicorn
  • HANO Motorsports
  • May 18, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
HANO Motorsports
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
For Sale SW MI: A tale of Two 20G Turbos
  • JmP6889928
  • Mar 21, 2022
  • Other Classifieds
Other Classifieds Mar 21, 2022
JmP6889928
