Can my baby handle 12lbs of boost???
Gotta 03 GT with magnaflow catback and xpipe, gettin gears and short shifter put in within a few days here, then next would be turbo
(thank god for credit cards) and a set of nitto's
. Im lookin to see if 12lbs of boost is too much for my very stock motor. I wouldn't be running the full 12 all the time of course but i guess im just worried about blowin the motor or causing problems and voiding the warranty. Anyone put this much boost on a stock new body style gt??
anyways, if you really want that kit, and you cant find one that is cheaper and less pounds of boost, you could get that kit, and set your blow off valve so that it releases at 9 lbs. but then again it will take a longer time for that turbo to spool do to its larger size. the larger size in effect is wasted, as you are not using the turbo to its fullest extent. i would forge it first, then go turbo. otherwise you are just wasting your cash, and most likly going to ruin an engine.
