  • 1994 - 1995 Specific Tech
turn signals/flashers having a problem?
  • Thread starter Thread starter jwater7
  • Start date Start date Sep 7, 2005
J
jwater7
104
  • Sep 7, 2005
Hoping someone might have had the same experience to direct me on the next step.
When I turn it on to the left, it "clicks" like normal. When I turn it to the right, it "clicks" at double or triple the rate and the indicator lamp on the dash doesn't show at all. It's also intermittent.
I've replaced the yellow "relay/flasher" by the fuse box, and it's still having problems.
Any ideas?
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Sep 7, 2005
  • Sep 7, 2005
I know they will flash at "double interval" if a bulb is out .... did you check to see?
J
jwater7
104
  • Sep 7, 2005
Yep, all the bulbs are just fine.
J
jwater7
104
  • Sep 8, 2005
Still can't figure it out. Anyone had this problem yet?
adam302gt
30
houston/CS
Sep 8, 2005
  • Sep 8, 2005
http://forums.stangnet.com/showthread.php?t=568558&highlight=turn+signal
FastFord
380
Washington
Sep 8, 2005
  • Sep 8, 2005
Yea, if its not the bulb(s).. then the blinker switch assembly needs replacing... mine sarted a couple of months ago... if I wiggle the switch when it does it.. it will stop and work fine.
J
jwater7
104
  • Sep 8, 2005
Thanks,
I'll have to try wiggling the handle a little too.
J
jwater7
104
  • Sep 9, 2005
Well, wiggling "seemed" to do something, I think I might have to replace the switch asm. How much work is it? is the instructions somewhere? costs?
Thanks for any info on this.
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
D
Turn signals work only with ignition on & Engine off.
  • DienstXIV
  • Jul 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 7, 2025
DienstXIV
D
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Z
Turn signals not working at all, but hazards do. 91 fox LX 5.0
  • Zeke1995
  • Jun 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
Jarhead67
J
