turn signals/flashers having a problem?
jwater7
104
Hoping someone might have had the same experience to direct me on the next step.
When I turn it on to the left, it "clicks" like normal. When I turn it to the right, it "clicks" at double or triple the rate and the indicator lamp on the dash doesn't show at all. It's also intermittent.
I've replaced the yellow "relay/flasher" by the fuse box, and it's still having problems.
Any ideas?
Yea, if its not the bulb(s).. then the blinker switch assembly needs replacing... mine sarted a couple of months ago... if I wiggle the switch when it does it.. it will stop and work fine.
Well, wiggling "seemed" to do something, I think I might have to replace the switch asm. How much work is it? is the instructions somewhere? costs?
Thanks for any info on this.
