Question. I just had EA calculate my injector timing after inputing my camshaft information. I had EA calculate injector timing using the Trailing (injector firing) and both the TDC and Exh close method (injector firing event). The numbers were difference for each range, unlike the stock settings which are set to all 300s - Is it ok to have different numbers.
Do I use the TDC or Exh close method numbers to input into the tables.
