Twisted Wedge owners?
I have a brand new set of the pushrods you need, they were used only to break in a Comp Cams 280H camshaft and never driven even one mile. I can take some pics when I get back from my trip this week if you want to strike up a deal. My heads are going on a roller engine now so I no longer need these things. Let me know, but I'm leaving in the morning for a trip and will be back Wed for a short time before I leave agian that day til Fri. I might be able to get back to you on Wed if you are interested.
Trick Flow has a page on installation -
Here you go.
289/302 engines with any recommended rocker arm (my emphasis)
If you aren't using something they recommend you'll have to measure them.
From TrickFlow
Camshaft Type Pushrod Length
Hydraulic roller 6.750 in.
Hydraulic flat tappet 7.300 in.
Thanks for the replies. I am ready to get my 66 back on the road again.
So it looks like the 7.300" should work according to Trick Flow's site. It also states that if you measure them with an adjustable pushrod that the measurement should be within 0.150 of 7.300" for a flat tappet cam.
Ronstang,
Are your pushrods the 7.300"? If they are just let me know and maybe we can work a deal.
I appreciate it.
Rodney
Hmm, kinda strange...I have Trick Flow brand pushrods themselves and they are marked 7.250 in length and they are the ones recommended by TFS to run with their head on a 302 with a flat tappet hydraulic camshaft. They hit just right on the valve with Ford Motorsports Roller rockers. Maybe you should make a quick and easy adjustable pushrod and actually check what you need. I will be back Wednesday sometime and will check here before I leave again.
The specs on Trick Flow's website states that the pushrods should be
7.300" +/- 0.150". Your 7.250" are well within that tolerance.
I was hoping there would be several people here that have around the same length so I could just order and go.....
I see the 5.0 crowd buying the 6.700" ones, so I was hoping it would be that easy for me. I will try checking for the correct length tonight.
I just contacted Trick Flow and they recommended the 7.250" pushrods for my early model 302 with flat tappet cam.
So Ronstang, how much do you want for your pushrods?
And, if I get them, would it be possible for you to send them Priority Mail tomorrow?
Thanks,
Rodney
