twisted wedge people
murphmaster5
115
PA
i wanted to get the afr 165 but the twisted wedge are cheaper but my question im worried about the piston valve clearence the afr's are 1.90 intake and the twisted wedge are 2.02 will i be okay with clearence and should i be looking for heads with 1.90 is 2.02 to much for my setup please help buying heads next week thanx
I had the same concern but went ahead a bought a set anyway. I run an e303 similar cam with stock pistons. I also run 1.6 roller rockers to keep it ok. I would always suggest to check with clay bar. Easier to check the wreck your new high dollar investment.
that the same setup i was running before i went with a 347 except for the intake, I was running a TFS street intake, an no problems, best time in the 1/4 was a 12.5. You should be doing O.K.
