two step
  • Thread starter Thread starter 87foxstang
  • Start date Start date Oct 30, 2007
First Prev 2 of 2
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Nov 1, 2007
#21
  • Nov 1, 2007
  • #21
87foxstang said:
hey thanks, i checked out that mallory box. But it doesnt seem to have a two step function.
http://www.centuryperformance.com/detail.asp?product_id=MAL-685
I have that box on my car, all you have to do is add a button to the wire coming off the box and then connect the other side of the button to a 12v source. The Mallory box you just set the rpm on the box, no chips to worry about. I use it to build boost on the line with my turbo car.
Stage up, hold the button down and put the pedal to the floor.
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Nov 1, 2007
#22
  • Nov 1, 2007
  • #22
87foxstang said:
when i was rebuilding the car, i took out the factory rev limiter because it was junk and didnt work. Now that im driving the car i figured i need a rev limiter to be safe. I saw that box with a two step and figured why not
You just think you did, the 6250 rev limiter is controlled through the computer.
"the fuel cut limiters at 7000rpm you're seeing are the failsafe/backup to the "soft" 6250 stock rev limiter. The stock rev limiter is in a pip rate scalar which is set to 961 by default. It limits the operating speed to that minimum rate per engine cycle (two crank revolutions). If it's sampled less than that per cycle then it limits RPM. So when you want to raise your stock rev limiter you lower that pip value."
Hope that helps.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Nov 1, 2007
#23
  • Nov 1, 2007
  • #23
I shift my stock tach at 65000 for reference... Ill post a dyno vid later of it hiting 7000!
87foxstang
Cromwell, CT
Nov 1, 2007
#24
  • Nov 1, 2007
  • #24
ohh ok, i see. I had the feeling that removing that box wouldnt do it but a "mechanic" told me it would
Damn 25th 65000 rpm? lol Yea get that dyno vid up
First Prev 2 of 2
A
Engine Turbo 5.0 Mustang bad misfire at WOT
  • AwxyMoron
  • Apr 3, 2021
  • 2 3
10K
Fox 5.0 Mustang Tech May 5, 2021
a91what
M
something shorted- car wont start - where do i start looking?
  • mostsmooth
  • Dec 12, 2020
  • 1994 - 1995 Specific Tech
4K
1994 - 1995 Specific Tech Jan 9, 2021
General karthief
Holley Sniper review - The good, the bad, and learn from my frustration
  • LX Dave
  • Aug 14, 2020
62K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 19, 2026
AeroCoupe
Progress Thread Haven't posted in a looong time... rescuing another 'stang... '89 Vert
  • ChillPhatCat
  • May 20, 2019
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 1, 2023
joeballz83
J
Need Help, Car Wont Start, I've Gone Through Both Checklists
  • 93silverlx50
  • Jul 22, 2017
  • 2 3
13K
Fox 5.0 Mustang Tech Apr 30, 2019
General karthief
