  • 2.3L (N/A & Turbo) Tech
Uh oh, engine codes
  • Thread starter Thread starter imapaintballa
  • Start date Start date Apr 7, 2007
I
imapaintballa
17
  • Apr 7, 2007
Hey everyone. Happy (non-denominational) Easter! Im getting codes 56, 65, and 66. These codes arent coming in 2's either, just one after the other. Is this normal?
These are the translations- KOEO test
56 - Vane Air Flow (VAF) or Mass Air Flow (MAF) sensor high
Transmission Oil Temperature sensor too high
65 - Check intermittent HO2S (signal or ground) - Fuel Control
66 - Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low - VAF MAF
Transmission Oil Temperature (TOT) signal low (possibly grounded) - Transmissions
Please tell me what to do. Thanks so much.
HyYoSilver
1,339
On a creeper, underneath the car
Apr 8, 2007
  • Apr 8, 2007
Ima, are these codes from your 92?
Any problems with how it runs?
The 56 and 66 are probably MAF related, and the 65 could be from the engine not being warmed up during the test and still being in open loop.
First thing to try is to un-plug the MAF sensor, and spray the connector with some WD-40. Push on the wiring loom as if to force the wires back into the plug, and see if that has any effect. Ford installed some bad connectors in some early 90's vehicles, and even had a recall on some models.....
I
imapaintballa
17
  • Apr 8, 2007
well yes, its from the 92. ill try the wd-40 tomorrow. whats wierd is that exhaust hose connected to the airbox. ill take it off and the car idles somewhat smooth for a 4-banger, but when i put it on, it seems like the car has a stumble. same when i take off the maf plug. the car idles very smooth with the maf disconnected.
HyYoSilver
1,339
Apr 9, 2007
  • Apr 9, 2007
All of that tends to point to the MAF as being the problem. I'd also try cleaning it before replacing. If you haven't done it before, do a search for "cleaning MAF" and you'll get lots of info on it.
Also check for vacuum leaks in the airtube between the MAF and throttle body. Make sure the clamps are secure and the tube isn't cracked.
There's a small PCV hose that runs from the throttle body to the valve cover (with a plastic elbow?), that meters PCV airflow; make sure it isn't clogged or cracked and leaking.
Basically you're looking for anything else that could cause the problem before replacing the MAF, since they're relatively expensive.....
I
imapaintballa
17
  • Apr 9, 2007
cleaned the maf today. same same. im not sure where to look for the pcv valve/hose, so maybe a pic of some sort might help. thanks for the help so far though.
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
