Well i was changing my clutch this weekend and i got it all done. While i was putting my H-pipe back on i stripped the stud in the manifold and now i can't get it out. :damnit: Anyone have any tips or anything???
Pittsas said:They make a metal piece to back out screws I'm not sure what it's called but they should sell them at any home depot or lowes. All you have to do is get a metal bit and drill a hole in the middle of the bolt and then put this metal piece in your drill and screw it into the hole you just drilled, it's reverse threaded so as you screw it in and it tightens it also losens the oringinal bolt. Cheap and easy fix.
Tap and die set. They work pretty good. Good luck.Pittsas said:They make a metal piece to back out screws I'm not sure what it's called but they should sell them at any home depot or lowes. All you have to do is get a metal bit and drill a hole in the middle of the bolt and then put this metal piece in your drill and screw it into the hole you just drilled, it's reverse threaded so as you screw it in and it tightens it also losens the oringinal bolt. Cheap and easy fix.
Modular2v said:i did the same exact thing on my buddys 96 cobra...i ended up replacing the damn exhaust manifold
Think he meant an EZout set.CManT1914 said:Tap and die set. They work pretty good. Good luck.
BooWFO said:Think he meant an EZout set.
