Engine Uncertain MAF voltage
  • Thread starter Thread starter PonyGTrider
  • Start date Start date Sep 16, 2019
First Prev 2 of 2
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Sep 18, 2019
#21
  • Sep 18, 2019
  • #21
Your fuel pressure at idle is high, should be around 34ish depending on the cam.
Decipha
222
36
39
New Orleans, LA
Sep 18, 2019
#22
  • Sep 18, 2019
  • #22
41psi with vac off and 39 with vac on is a major problem. You should be around 32psi or so with the vac line hooked up. Unless of course you cam gives you literally no vacuum.
Boostedpimp
20+ Year Stangneter
May 8, 2003
1,451
493
154
NJ
Sep 18, 2019
#23
  • Sep 18, 2019
  • #23
Noobz347 said:
Oh, it can be done. Just not at 46 psi. At one time, I pushed mine upwards of 90 psi and supported a blown 302 to nearly 400 RW with 225L HP Walbro, and an FMU.
This was by no means ideal and things got considerably better when I swapped to 42 and kept pressure much closer to stock levels. The whole fuel curve improved.
and I thought I had balls
PonyGTrider
5 Year Member
Feb 27, 2019
646
115
63
Mexico
Sep 18, 2019
#24
  • Sep 18, 2019
  • #24
There you have it, there are some crazy dudes that will do the unthinkable. I applaud those guys willing to try anything!!!
PonyGTrider
5 Year Member
Feb 27, 2019
646
115
63
Mexico
Sep 18, 2019
#25
  • Sep 18, 2019
  • #25
Thank you for that observation, I will have to re check my numbers and will post the results.
PonyGTrider
5 Year Member
Feb 27, 2019
646
115
63
Mexico
Sep 20, 2019
#26
  • Sep 20, 2019
  • #26
Ok guys this is what I did:
I re checked my fuel pressure numbers and this is what I got, vacuum OFF 39 psi vacuum on 34psi.
I have a 70mm MAF tube with sensor F2VF-12B579-AA AFH70 which I just installed and disconnected my battery to reset the ECM. Runs fine, the only problem is that I forgot my DMM to measure the voltage on that sensor to see if it makes any difference compared with the stock sensor.
I know it is kind of hard for you to tell me this but have to ask, are there any adjustments I have to do on the fuel pressure, or it will run fine @34 psi?
Eventually I want to go to 24 lb injectors and I’ve been reading about the best way to do it, if you can give me your opinion about this would be great... MAF/tube calibrated for 24 or performance chip??? I’ve heard that the first option is just cheating to the ECM and in my opinion it is kind of... Cheesy
Thank you all
PonyGTrider
5 Year Member
Feb 27, 2019
646
115
63
Mexico
Sep 21, 2019
#27
  • Sep 21, 2019
  • #27
I measured the voltage on this other MAF sensor with the 70mm tube and it gave me 1.16 - 1.18 Volts at idle, so I guess the stock sensor and 55mm tube is good..
Decipha
222
36
39
New Orleans, LA
Sep 21, 2019
#28
  • Sep 21, 2019
  • #28
you do know putting in larger injectors gives you 0 additional power.
Unless you have a head swap or plan on spraying a dry shot theres no need in swapping the injectors
vristang
4,933
101
124
Seattle
Sep 27, 2019
#29
  • Sep 27, 2019
  • #29
Is it running the same, or actually better?
First Prev 2 of 2
Engine 1988 Ford Mustang throwing 2 OBD-1 codes (32 and 63) rough cold start and initial idle
  • mikeah
  • Nov 16, 2026
Fox 5.0 Mustang Tech Nov 17, 2026
mikeah
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
