Underdrive pulleys...convince me that they work.
Ive been looking towards the final little cheap mods to do to my car and underdrive pulleys are on the list. I always thought these things were a gimmic and I dont believe they do anything. Basically Im asking if anyone has any solid info to prove me wrong. If they work then great, its like 100 bucks for up to 10hp but for some reason I dont think its that easy.
bubba-dough
1,044
Indiana
Maybe I am the lone person here but I think they are absolutely worthless junk. They are not worth the money. They gain what, 2hp on the wheels? At the cost of slowing you acc. Save your money. You will see more gain by eliminating the clutch fan like mentioned above.
http://en.wikipedia.org/wiki/Underdrive_pulleys
An Underdrive pulley refers to an aftermarket crankshaft or accessory pulley (such as an alternator pulley) that is designed to drive a vehicle's accessories at a slower rate than stock. Originally they were invented for race cars in the 1950s and 60s, whose engines had been modified and ran at higher RPMs for longer periods of time than the manufacturers had intended. It was therefore necessary to underdrive the belt-driven accessories (among other things like the water pump) to keep the accessories from burning out and the engines running reliably.
Presently, these pulleys are marketed as performance enhancers that actually produce additional torque and horsepower by reducing parasitic drag caused by belt-driven accessories, or by being lighter and reducing rotational mass, or both. However, the gain is usually minimal, on the order of 1-6 wheel horsepower depending on the engine. There are trade-offs for this "free power," however.
Changing the original crankshaft pulley can have negative effects on the harmonics of the crankshaft: a pulley that is too light or not properly weighted cannot reliably balance natural frequencies that occur along the length of the crankshaft at certain RPMs. The original pulley may have been carefully designed, balanced and weighted to counteract (harmonically dampen) this naturally occurring harmonic frequency, and without it, eventual engine damage may result. See: Engine Balancing
A less severe side effect is somewhat intended by the design of these pulleys. Since the alternator, power steering, and/or air conditioning units are not spinning as fast, corresponding dips in alternator voltage, power assist, and A/C effectiveness may be noticeable, especially at idle. The headlights may dim when coming to a stop, or the stereo may lower in volume, for instance. For a race car, this is not of concern, but for a daily driven vehicle it can be an annoyance.
seijirou
2,417
DFW
I have not personally done it but I remember hearing someone flat out taking the belt off for a quick dyno pull and the gain was something like 2hp at the wheels, but back to back dyno pulls often vary by that much.
Conclusion is that if no belt is negligable, underdrives aren't going to make you power, they'll only save your accessories if you turn alot of rpms like mentioned above.
cobra2798
303
Clermont, Florida
You can feel a difference. I put mine on (March Pulley's) and it wasnt the power difference that I felt but the car revved quicker. it feels good and I may have gained a few ponies but your really not gonna feal 5-10 hp in your ass so who knows. For the $50 I paid and the hour it took me to install I guess it was worth it.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,513
2,854
234
Dublin GA
Being that you are in Canada, you might get away with underdrive pulleys. The negative effects are low output from the alternator at idle/low speed and a tendency to overheat in slow traffic. Just don't get caught in a traffic jam at night, your battery may take a beating.
Canada has much cooler summers than Florida, Arizona, or New Mexico, so the overheat problem may never surface. For those of us whose summertime temps hit 95 F or more and live in big cities, the overheating problem can be very real. The hotter it is outside, the harder it is for the radiator to get rid of the engine heat into the air. The massive concrete roadways heat up the air even more, making for a 140 F pavement and air temp next to the pavement.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Excellent info...but remember if you perform 10 mods consisting of 3-5 hp your going to end up with a substantial gain. Example would be my Efan upgrade...on the dyno the returns were excellent as RPM climbed, biggest gains found at 5800 but really there were gains all through the graph after 3000 rpm.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
yes there are negitive effects such as the stop and go traffic issue but that isn't so much the underdrive pullies fault. Odds are you have modded your mustang quite a bit and you have not done much to the cooling system. It was designed for 225hp after all. If you are going to get 350 hp out of the 302 then it stands to reason that because of the extra heat you will need to upgrade the cooling system. A high flow water pump (perhaps even a electric one to negate the effects as metioned above of the UD pully) a 3 or 4 core rad and a electric fan that moves a lot of air ( not a black magic fan).
jfran430
36
Connecticut
SO wait i have a question on all of this ... i want to put unnderirve pullies and an electri fan on my carr ... well i wanted to but now im not so sure ... its sounds to me like i HAVE to put a fan in if i want pullies which i was going to do anyways .. what kind of fan though?? and how do the fans hook up?? do i just connect it to the seloniod??
Daggar
3,902
You are not alone. The only REAL dyno information I've seen on this came from two locations:
The first was an 8 cylinder but not a mustang. With the addition of JUST underdrive pullies, the dyno showed a whopping 3 HP to the wheels. There was no real way to know for sure whether this was from the pullies itself or just a +/- error for the dyno.
The second isntance was on a car where the serpantive belt was removed all together. The total gain was between 11 and 15 HP. Now consider that a set of underdrive pullies give a 20% reduction. 15 RWHP (benefit of the doubt) x .20=3 HP.
Pretty consistent with what was done on the 8 cylinder above. :shrug:
I would LOVE to see an engine dyno with before and after graphs for JUST pullies vs. the normal accessories.
As for the individual who said he "felt" a 10 HP increase with his seat-of-the-pants dyno.... well.... I just gotta call :bs: Sorry bro.
Your mechanical fan will be the largest part of your accessory rotational loss. I REALLY see no need of a 20% under drive if you've taken the largest rotational resistance out of the acessory package. :shrug:
If you want to get pullies because they look nice... Go For It! I recommend that you keep your accessories spinning at the rates they belong though.
Topdowncruise
207
Canada
Mustang Enthusiast ran an article where they claimed through dyno testing that underdrive pullies added 13 hp and 8 lbs. torque on a mildly modified 5 liter.If anyone is interested the article called Budget Boltons Part 2 is available on the Comp. Cams website.
ozanracing
172
Nobody else cought this BS?? Come on! (WHAT IS THE JOB OF THE HARMONIC BALANCER?)
Seriusly guys...
:nono:
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
its no gimmick, they do work. depending on your combo it may not help much. but they do reduce drag so they are actually helping. just might not be much.
if u want them and dont want to spend 100$, get a cheap set off ebay. i bought my pullies off ebay for 30 bucks new. look great and work perfect. its a pulley, there isnt anything to mess up. so there isnt any "ebay= junk" arguement for them.
90mustangGT
I felt sorry for girls because
2,773
Dallas, GA
The accesories have rotating mass, most accesories spin faster than the engine. Consider this rotating mass and consider that you will have to accelerate these masses from 800-6000rpm in a relativly short time, (and that is considering the accesorie is only on a 1:1 ratio) especially in low gears where it wil have to accelerate these masses in a second or two. Then consider the resistance of these accesories. That is a considerable amount of energy.
This theory about "we took the belt off all togeather" isn't all that accurate because with an EFI car, "did the voltage stay at the same volts as is the belt was there?" which is probally not.
One problem with UD pullies and electronicly controlled cars is they are very reliant on the function of thier charging system, and they also draw a lot of energy. This can cause problems with sensor readings, and the function of the computer. I put an UD pully on my Camaro, made the ignition go nuts.
U/D pullies, worthwhile mod but they have thier pro's and con's. The "street" kits have a very slight reduction in accesorey speed, very little effect, the "race" kits you will definatly know they are on there, but the "cons" are much worse.
I used to bypass the P/S pump when my engine was about stock and dropped .2 in the 1/8th mile.
68keyblr
946
21
49
Arizona
Horsepower TV did a dyno run before and after with underdrive pulleys on a motor with the TrickFlow top end kit. The gain was 4-5 HP.
For me it's just not worth the negative trade offs on a street car.
Daggar
3,902
Not as inaccurate as you might think. The test was performed with a shop charger feeding the battery. I'm reasonably sure (although I didn't think to look specifically) that the voltage/current from the charger was at LEAST as high as that output from the asthmatic 2G in the car. :)
To date, I've not seen any back to back dyno data that shows more than a few HP increase from a pulley swap. One day, I'll conduct my own test. I run all stock pullies at present and would love to swap on a set from one of the better companies on a Mustang Dyno to get a final result.
Think about it though... a 20% reduction is nothing.... Even if you were to get 30 HP from having no accessories, it would still only equate to 6 HP with a 20% under drive. 60 HP at 20% would only free up 12 at 20% and a 100 HP no-accessory increase would STILL be only 20HP at the crank. LOL Subract another 20 HP for drivetrain loss and you end up with 4 HP at the wheels.
I would hazard a guess that other factors were involved in your 2/10th track gain. Perhaps track condition, temp, humidity... the list goes on.
