Underdrive Pulley's
savegoodautonfg
1,085
I was looking into getting Underdrive Pulleys. what exactly are they and what do they do. supposevely they add some horsepower and are good for 5.0's and don't look to expensive so i was wondering about them.
I have stock radiator and stock fan. is this going to matter? if anything to do with voltage i have a 140 amp alternator.
i was looking around at a few different ones.
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=BBK-1553 1&comp=LRS
http://cgi.ebay.com/ebaymotors/86-9...016QQitemZ260023985400QQrdZ1QQsspagenameZWDVW
http://cgi.ebay.com/ebaymotors/83-9...001QQitemZ110025135837QQrdZ1QQsspagenameZWDVW
I like the 2nd one because they are polished and they look awesomes. $90.00 for polished is'nt bad. but then of course Mac and BBK are brand names. what do you guys think?
Also if it helps at all with the cooling issues that i hear some people get. would it help if i bypassed the smog pump cause i really don't need it seeing that i have no cats at all.
I have the BBK polished ones. They work great. :nice:
88Stang331 said:
What do they do? Reduce "parasitic drag" on the pullies which are turned by the crank. Doesn't really do a whole lot as far as netting more hp/$
+1
They sure as hell don't make you any more hp.
They usually only include the crank pully which is underdriven, the waterpump pully which is overdriven to compensate for the slower belt now and sometimes they also include a overdriven alternater pully. Net gain is probably very small if any. Netting a bigger drag reduction would be to dump the smog, powersteering, and get an electric fan though ;) (and maybe ac but I like the cold air)
--Since the waterpump will turn nearly the same speed as stock it shouldn't affect your stock fan much I don't believe but I dunno for sure. I have an electric one :shrug:
You will get a slightly noticeable increase in power. The crank pulley is significantly smaller than stock. Basically for every rotation of the crankshaft it turns your accessories less because of the smaller pulley, reducing the amount of drag on the engine. The set should also include a larger water pump and larger alt. pulley, resulting in them turning slower than factory (some sets have a smaller alt. pulley to offset the crank diameter). If anything it may hurt your cooling and drop your voltage, as it did with mine. I don't recommend changing your alt. pulley as the difference isn't worth the effort. Come to think of it, I wouldn't recommend u/d pullies at all as it's a hokey way of extracting more power from the engine. Save your $$$ and get more worthwhile bolt-on's like mass air, throttle body, intake, ect. You will enjoy them more and your accessories will thank you.
I already have a cold air intake and a bigger throttle body.
Anyone else opinions on the underdrive pulleys?
+1 with that statement. Underdrives ARE NOT worth the time. I've had them and experienced all the negatives. Keep the stock pullies and get a nice electric fan and 3G.
