Avoid placing any extra load on the stock alternator - here's why:
Figure this:
Ignition system & computer = 12 amps
Fuel pump = 12 amps
Exterior lights = 15 amps
Fan (heater or A/C) = 15 amps (can run between 5-25 amps depending on setting)
Radio & instruments = 10 amps
Wipers = 10 amps
That's grand total of 74 amps from a 65 amp alternator. Talk about overdrawn at the bank!
Alternators have to spin at a minimum speed to power the electrical system. Using an underdrive pulley reduces the alternator speed and output at idle & low speeds.
If you live in the south in a big city, the underdrive pulleys need a bigger radiator to help cool the engine. If you live north of North Carolina, it probably doesn't get hot enough with stock engine to be a problem. Live in Florida or Arizona and you're asking for trouble.
