On the front suspension,the driver side wheel/tire comes flush to the edge of the fender lip but the passenger side wheel/tire is about an inch short from being flush with the edge of the fender. Im trying to figure out if something is off with the suspension or if the fender is off. I've got all aftermarket suspension. I checked the K member and its perfectly sqaure with the frame. I also measured the length of the control arms and both driver / passenger side are the same lengthWhat other measurements can I take to decide which part is the culprit causing the uneven spacing from driver to passenger side?
(kind of hard to describe) The control arm goes from shallow to deep in the same way, so you have to turn the spring so it sits in the control arm correctly. If one spring sat correcttly, and the other was not, one side of the car would sit higher then the other. Maybe someone with some pictures can chime in.
