Unhappy, HDX total crap
  • Thread starter Thread starter 91foxbod50
  • Start date Start date Apr 1, 2010
  • 3
First Prev 2 of 3 Next Last
9
91foxbod50
486
#21
  • Apr 2, 2010
  • #21
Geeesh, Fine Fine ill try the cable... Should i go with a stock one? I have an aftermarket quadrant from bbk so idk if that will work? And is the stock one adjustable?
Tanus
847
A to the Z
Apr 2, 2010
#22
  • Apr 2, 2010
  • #22
90lxcoupe said:
Also, next time, dont bother "breaking in" a clutch, ive never done that 500 mile BS and never had a problem, drive it nice for a few heat cycles and let the punishment begin.
+1, my centerforce clutch is like 4 years old, and has hundreds of launchs on slicks under its belt.
A properly installed & driven clutch set-up will last a long time even with high HP.
Kdubslugga
1,515
Akron, OH
Apr 2, 2010
#23
  • Apr 2, 2010
  • #23
Not sure what an HDX is but I have a Ram Heavy Duty Powergrip and the thing is awesome, and Im making over 500 to the wheels. That sucks though, is the HDX a metallic clutch??
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Apr 2, 2010
#24
  • Apr 2, 2010
  • #24
The clutch isn't the problem, my HDx grabs hard. OP needs to explore some other options before jumping to conclusions...
9
91foxbod50
486
#25
  • Apr 3, 2010
  • #25
I feel like im getting burned for posting this. Best of all no one is listening to what ive been saying. How is a clutch cable going to effect the clutch from slipping when its set so low its hard to get into gear with the clutch pedal to the floor? Isnt that a sign that the clutch is almost engaged even when the pedal is pressed to the floor?doesnt this insinuate the cable is fine? I must be stuck on stupid because ive been saying this the entire time and nobody has acknowledged it.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Apr 3, 2010
#26
  • Apr 3, 2010
  • #26
no thats a sign that its set wrong
9
91foxbod50
486
#27
  • Apr 3, 2010
  • #27
Okay, i just finished trying to adjust this again.
With an inch of play in the pedal it will not go into gear. With the clutch engaged trans in first it will roll foward when trying to start.
Half inch of play in pedal, same situation. Will not go into gear..
No play in pedal, Goes in gear, but not with ease. However it slips.
Checked quadrant, nothing seems out of place, Straight shot to the fork. however their is a clicking coming from somewhere i cant pin point. I feel it in the clutch pedal, when i compress and depress. Rear main seal, not leaking its brand new with the kit.
My only other thought, other then the clutch being fried is the steel bearing retainer has some issue. But its brand new, so maybe not. I'll have to wait until monday as i had to do these adjustments on my back and i need someone to help me.
Blandnuts
I don't swallow; I only swoosh
1,172
124
124
FloorDuh
Apr 4, 2010
#28
  • Apr 4, 2010
  • #28
I've been waiting on the info about the flywheel. What kind, new, old/resurfaced, style etc?...... What does it look like now?
If the cable is properly set up (which it seems to be), then it's between the clutch, pressure plate, and flywheel (unless you have a 600hp monster on a OE clutch w/ slicks ). I will add, that it's possible to receive a new part that is bad. But, I would first go through a checklist to come to that conclusion...
Blandnuts
1,172
124
124
FloorDuh
Apr 4, 2010
#29
  • Apr 4, 2010
  • #29
The popping is probably because of the play you have in the cable.
9
91foxbod50
486
#30
  • Apr 4, 2010
  • #30
Flywheel is brand new, came with the kit. And i cleaned it before install to ensure all packing grease was off.
Tanus
847
A to the Z
Apr 4, 2010
#31
  • Apr 4, 2010
  • #31
no ones bashing you, just telling you that its installed/driven wrong, if a brand new clutch is slipping then 99% chances are that its user error
set it so it disengages at 1/4 the way in (3/4 away from floor) then see what happens
9
91foxbod50
486
#32
  • Apr 4, 2010
  • #32
I had it set up like that, but it will still slip. Maybe the clutch is glazed
Blandnuts
1,172
124
124
FloorDuh
Apr 4, 2010
#33
  • Apr 4, 2010
  • #33
Well, it's time to inspect the flywheel, clutch, and pressure plate. I thought maybe the flywheel was mismatched, but it should be fine since it's a kit.
clement
1,104
52
59
Oak Cliff
Apr 6, 2010
#34
  • Apr 6, 2010
  • #34
people are saying to check other things because a lot of us have been using Rams for close to 20 years without issue.
just because the engagement is good doesnt mean the shift fork, or the firewall isnt flexing causing an engagement problem. not to mention that clutch cables dont last forever. how old is yours? they can stretch.
i have seen brand new flywheels that needed to be surfaced out of the box. that can certainly cause a clutch to slip. or if the installer didnt clean the surface after getting his greasy paws on the flywheel that is another culprit. not to mention if your rear main, or the back of your intake leaks oil. that will kill a clutch in a hurry. or too much grease on the throwout bearing.
you are ASSUMING the clutch is bad. if you didnt install it yourself, even if the cable is good, that is only eliminating one possible cause. that alone doesnt mean the clutch is bad. the clutch could be bad, but if something else caused the problem, you put another clutch in it and you are going to go through this all over again. is that what you want?
9
91foxbod50
486
#35
  • Apr 6, 2010
  • #35
Do you really think i want to pull the trans out.. again? No, i just want to drive the car with no problems. I'm not going to say i checked something and lie about it. I want to avoid pulling the trans out completely. If you read the entire thread you would have noticed that the engagement is rough.
Theirs simply no leaks, Ive checked everything for leaks. The Motor is brand new, all new gaskets. And ive looked over them last time i had it up on a lift. Maybe this clutch just cant handle the power im putting down. It says its rated to 400 rwhp and im only putting down 348. Everything was working fine, its not like the first time i put it to wood it slipped. Im not running any kind of tire on it. The cable is not brand new, its a year old. However if you read the entire thread i'd hope itd make more sense to you about my problem.
Brand new flywheel being resurfaced? Maybe thats the problem, I inspected it and it seemed fine, however maybe i missed something.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Apr 6, 2010
#36
  • Apr 6, 2010
  • #36
FWIW ive toasted clutch cables in less than a month before, the aftermarket ones are junk and dont last at all, im getting the MM kit next
clement
1,104
52
59
Oak Cliff
Apr 6, 2010
#37
  • Apr 6, 2010
  • #37
i read the initial post. i dont know about you, but at work on my lunch break i have to pick and choose. i wont respond further since i dont have the time to read every word in the 2 page thread.
9
91foxbod50
486
#38
  • Apr 6, 2010
  • #38
Took the trans out clutch is badly clazed. Oddly enought i ordered the same clutch but somehow both pressure plate and disk are different from origional.
Blandnuts
1,172
124
124
FloorDuh
Apr 7, 2010
#39
  • Apr 7, 2010
  • #39
How so?
9
91foxbod50
486
#40
  • Apr 7, 2010
  • #40
Well the thickness of the disk is different and also the disk has no serial number on the origional. The pressure plate on the origional doesnt have any identification nor state ots ram. But the new one does. The design of the crevises on the disk are also different.
  • 3
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
HP woes with Sniper Sytem
  • Stang_1973
  • Mar 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
J
Car Diagnosis
  • j.2016
  • Aug 31, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 31, 2025
