Upgrading Engine
  • Thread starter Thread starter Branco Ramirez
  • Start date Start date Mar 12, 2016
Branco Ramirez
  • Mar 12, 2016
I just added all these parts to my motor I just haven't put it in my car which is a 91 foxbody 5.0. Approximate how much horsepower would I gain total before a tune up and after a tune up? Cause I don't know if I need a 31 spline axle to support that power or what else do I need to upgrade? if someone can help me out here I don't want to ruin anything
TrickFlow upper and Lower manifold
TrickFlow Valve Covers
GT-40p Heads
Upgraded Valve Springs
Scorpion Roller Rockers
Pushrods
Pistons Bored .30 Over
70mm Throttle Body
Shorty Headers
Roller Lifters
F303 Camshaft
Ford Racing Pullies
24lbs Injectors
MAF 24lbs
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Mar 13, 2016
  • Mar 13, 2016
You'll make around 260rwhp and shouldn't need a tune. Also stock 28 spline axles are fine unless you're going to the dragstrip and plan on using slicks. What transmission are you running? If it's an automatic you're going to want to do some upgrades like torque converter and shift kit. If it's a manual install a good clutch and mm cable kit. Also with that cam you're going to need rear gears if you haven't installed any yet. I like 3.73's for a manual trans and 3.73 or 4.10's if automatic.
Reactions: jrichker and stykthyn
stykthyn
5,232
2,652
223
gainesville
Mar 13, 2016
  • Mar 13, 2016
You don't need 24s and a matching maf for that combo. I would suggest at least gears with that f cam. It has a huge dead spot below 2k rpms that will kill take off in street driving
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Mar 13, 2016
  • Mar 13, 2016
24's aren't needed but if you already have thm and the matching MAF use them. It won;t hurt anything. You jsut may need to adjsut your FP a little if your plugs read rich.
CarMichael Angelo
8,909
234
Birmingham, al
Mar 14, 2016
  • Mar 14, 2016
And to second,...as long as you keep the car on the street.
28 splines axles will withstand many times that power, as wheel spin on street tires will be the "cushion" that un couples the axles from the direct link that a slick, and a drag strip will create.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Engine Finishing up 331 build
  • RedFury5.0
  • Mar 21, 2025
Fox 5.0 Mustang Tech Apr 20, 2025
RedFury5.0
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
D
Heads Cam Intake
  • dropteeth
  • Sep 19, 2023
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 19, 2023
dropteeth
D
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
