Upgrading Engine
Branco Ramirez
I just added all these parts to my motor I just haven't put it in my car which is a 91 foxbody 5.0. Approximate how much horsepower would I gain total before a tune up and after a tune up? Cause I don't know if I need a 31 spline axle to support that power or what else do I need to upgrade? if someone can help me out here I don't want to ruin anything
TrickFlow upper and Lower manifold
TrickFlow Valve Covers
GT-40p Heads
Upgraded Valve Springs
Scorpion Roller Rockers
Pushrods
Pistons Bored .30 Over
70mm Throttle Body
Shorty Headers
Roller Lifters
F303 Camshaft
Ford Racing Pullies
24lbs Injectors
MAF 24lbs
You'll make around 260rwhp and shouldn't need a tune. Also stock 28 spline axles are fine unless you're going to the dragstrip and plan on using slicks. What transmission are you running? If it's an automatic you're going to want to do some upgrades like torque converter and shift kit. If it's a manual install a good clutch and mm cable kit. Also with that cam you're going to need rear gears if you haven't installed any yet. I like 3.73's for a manual trans and 3.73 or 4.10's if automatic.
You don't need 24s and a matching maf for that combo. I would suggest at least gears with that f cam. It has a huge dead spot below 2k rpms that will kill take off in street driving
And to second,...as long as you keep the car on the street.
28 splines axles will withstand many times that power, as wheel spin on street tires will be the "cushion" that un couples the axles from the direct link that a slick, and a drag strip will create.
