Upper suspension arm relocation
  • Thread starter Thread starter cobraindy
  • Start date Start date Nov 29, 2004
C
cobraindy
  • Nov 29, 2004
Help!
I want to do the Shelby 1" drop on my upper arm. Do the new holes go above (as I think) or below the original holes?
Also, are the spring seats (perches) on the lower arms suposed to be real stiff when new? There is spring end "stop" on one side of the perch. Does it go toward the engine side, the wheel side or does it matter? The way mine are installe, it looks like the spring installation will not line up correctly with the angle of the perch.
Thanks,
Steve
R
Ronstang
1,294
Houston Texas
Nov 29, 2004
  • Nov 29, 2004
The new holes go below the orginal ones. The perches are supposed to be stiff, and I usually put the end with the stops towards the inside (engine side).
krash kendall
1,258
Aldergrove, B.C. Canada
Nov 29, 2004
  • Nov 29, 2004
All the infomation you need for the Shelby drop, including a template for both 65-66 and 67-70 can be found at the bottom of the page on this link.
Shelby Drop
65stanger
big blue fuzzy closet monster
3,885
In the Deepest, Darkest, corner of THE CLOSET, whe
Nov 29, 2004
  • Nov 29, 2004
Be careful if you print the template out, it doesn't always print full size (off by ~1/16" to 1/8" and the template doesn't show the dimension between the center lines of the holes.
krash kendall
1,258
Nov 29, 2004
  • Nov 29, 2004
Thanks BBFCM, I noticed that as well the first time I printed it for my reference binder. The print I made came out actual size.
The measurements center to center appear to be:
'65-'66 = 3.75"
'67-'70 = 4.75"
Please advise me if incorrect in any way. Hope you had a good weekend.
65stanger
3,885
Nov 29, 2004
  • Nov 29, 2004
'65-'66 = 3.75"
'67-'70 = 4.75"
The '65-'66 measurement is what I got (I measured from center of the bolts on my new upper arms), using this measurement and the paper template, I made a template out of aluminum on Saturday. (I also test fit it over the bolts on my new upper control arm!)
Once the weather gets warm all I'll have to do is bolt the template in place and drill pilot holes, drop the template, then step-drill up to the final size!
krash kendall
1,258
Nov 29, 2004
  • Nov 29, 2004
That's what I'm planning as well. Only I'm probably going to use one of the two CNC machines running behind me right now to pump out a dozen or so templates with instructions ingraved on them and see if they'll sell for a few bucks each. There's also '77 granada daily driver for sale on my way to work I'm thinking about buying for the disk conversion. I have to prioretize my wife and two year old son's christmas first before justifying purchasing a 28 year old granada though. I just don't think she'd understand.
65stanger
3,885
Nov 29, 2004
  • Nov 29, 2004
krash kendall said:
..............There's also '77 granada daily driver for sale on my way to work I'm thinking about buying for the disk conversion. I have to prioretize my wife and two year old son's christmas first before justifying purchasing a 28 year old granada though. I just don't think she'd understand.
Ya, but your son would LOVE it! What other 2 yr old in the neighborhood would have a '77 Granada up on blocks for a playhouse!
krash kendall
1,258
Nov 29, 2004
  • Nov 29, 2004
You would be surprized how many!
65stanger
3,885
Nov 29, 2004
#10
  • Nov 29, 2004
  • #10
Hmmm.....A lot of rednecks in B.C.? I'd feel right at home!
krash kendall
1,258
Nov 29, 2004
#11
  • Nov 29, 2004
  • #11
Not so much rednecks where I am, just guys who don't know when to say "it's all over" to their car and move on. There's always the hope that some silver bullet will bring that Lada or Buick Century back to life. The most common method of restoration is removing the blue tarp in favour of the more year correct orange tarp.
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
6K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Today at 4:28 AM
2v_johnny
