So i just installed the plastic UPR boostmaster pipe but am having problems with the bypass valve that i rigged up. i used a 90 degree elbow from home depot and attached one side to the pipe with some PVC glue and the other side clamped to the hose from the bottom of the bypass valve. it worked good for a while but then with the heat from the motor, it ended up blowing off the pipe and the elbow disfigured from the heat so the hose also came off. Any suggestions?? Pics would also be a HUGE help. I seem to remember a post about this i just cant for the life of me find it. Thanks in advance guys!!
