The directions for the c/c plate installation says to put the large spacer on the strut, under the plate, and the med. and small spacer above the plate. This will cause the strut shaft to be riding directly on the c/c plate bearing. Should the rubber bushing on the stock strut be against the bottom of the plate, like the oem mounts? I have lowered the front approx. 2 inches, and need to put the spacers above the plate to increase strut travel. The small spacer will sit below the rubber bushing at the top of the strut, and the strut will be against the bottom of the c/c plate. Is this OK?
