  • SN95 4.6L Mustang Tech
UPR X-PIPE Install Problem, Please Help!
  • Thread starter Thread starter derek02gt
  • Start date Start date May 29, 2004
D
derek02gt
255
  • May 29, 2004
hey whats up guys..i bought the upr x-pipe on friday to match my slp loudmouth..but ran into a small problem..me and my friend jacked up the car and removed the first 4 bolts..(2 on each side) that connect the stock h-pipe to the exhaust..then we had 4 more bolts to work with...the 4 that connect the stock h-pipe to the headers..well we removed the 1st one on the passenger side..but the one where you need a special type of swivel to even access it..well, we stripped that bolt, im sure you guys know the bolt im talking about..took it tok a shop with a list and after changing my oil, they said they would put on the x-pipe for $25 dollars..well, they couldnt get the stripped bolt loose..its not even that stripped..it looks like it is still good..they said the only way to get the bolt out is to torch it out, but they will have to remove the starter box and some ignition wires...is this my only option?to remove the stripped bolt and stock h and put on my new upr they quoted me $90..is it worth it guys? they said they cant get a air-gun up in that tight space....my questions are
1. is their some type of socket made especially for strippled bolts that will grab that bolt?
2. cant i frickin drill that sucker out????
3. what do you guys recommend, i want my x-pipe on!!!
Smooth_Operator
Banned
Oct 13, 2003
69
"Too bad drinking scotch isn't a paying job o
May 29, 2004
  • May 29, 2004
1) Yes there are special sockets made for stripped bolts. You can buy them at Sears.
2) Yes you can drill it out, but what if you destroy the threading in the process?
3) Go to Sears and buy the Craftsman sockets design to remove stripped bolts.
Smooth_Operator
Banned
Oct 13, 2003
69
May 29, 2004
  • May 29, 2004
Here's a link.
http://www.sears.com/sr/craftsman/w...p?BV_UseBVCookie=Yes&vertical=TOOL&Tool_Id=45
D
derek02gt
255
  • May 30, 2004
thanks for the quick reply..im going to sears tommorow to purchase it..with that i should be ok right?none of the other options necessary?
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
May 30, 2004
  • May 30, 2004
Spray the hell out of it with PB Blaster and let it sit for a while. It will allow it to loosen up and maybe easier to get out. What size socket were you using?
kboy262
437
Atlanta-Kennesaw
May 30, 2004
  • May 30, 2004
You can also take a 6-point socket a tad smaller and jam onto the nut. The down side is that you lose a socket. I would follow the advice on going to Sears for the swivels. Gives a good excuse to buy more tools!
D
derek02gt
255
  • May 30, 2004
thanks for the great advice guys..kboy that is a very interesting idea..its sad that mechanics at a frickin auto repair shop cant even think of that crap..once you jam the socket into the nut..it will become part of the stripped bolt and then all you have to do is remove the socket with the right wrench?? also i'll pick up a bottle of pb blaster...is paying $90 wayyy too much??
D
derek02gt
255
  • May 30, 2004
they tried a bunch of socket sizes..i know one of them was 5/8th..
kboy262
437
Atlanta-Kennesaw
May 30, 2004
  • May 30, 2004
I believe the correct size is around a 18mm or 17mm. I should remember since I changed it so many d*** times. Not sure how much PB blaster is. I do know that it suppose to do wonders. Me I was cheap and used a $3 can of wd-40.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
May 30, 2004
#10
  • May 30, 2004
  • #10
PB Blaster is about the same price and is right next to the WD-40 at Walmart.
The socket size is 18mm...I bought it special for the install of my pipe. (I've done it twice now and can do it in under an hour).
Red mustang Gt 46
601
Good ol' Maryland
May 30, 2004
#11
  • May 30, 2004
  • #11
It's easier to get the bolts off when the exhaust is WARM...just fyi...use PB liberally
J
jas142
1,358
#12
  • May 30, 2004
  • #12
Damn that bolt was a pain in the ass, I remember it well. Yea, use the special socket for stripped bolts. If you use air tools, its alot easier.
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
