Used FMS 4.10 gears
TheBocSez
652
Converse, TX
Im sure several wont agree, but I put a used set of 4.10's in my 91, the pinion bearing was still pressed onto it, I just reused the shims that were in my current set up, put it all together and havent had a single problem or noise.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,513
2,854
234
Dublin GA
If you can install them yourself, it might be worth a try. This is not a project that should be attempted if you haven't done several sets of Ford gears prior to trying to do it. The cost of professional installation is high enough that if the gears are bad, you will be out a fair amount of $$$.
GTOreturns
Well-Known Member
Oct 1, 2003
40
12
59
West Coast Best Coast
I bought a set of 410's on this site for about the same price.(was a few years ago) Went to have them installed and my mechanic said they will be real noisy because they were pretty worn. If its from a good source go for it. If theres any question in your mind, Id get new!
