Yes, I plan on rebuilding the trac lok and install the gears myself. Whenever I may decide to do all of this, I will do it all in one shot. Just considering saving nearly $100 buying a good looking used set.HISSIN50 said:Are you installing them yourself? If so, that is the only way I would consider it. Even then, I lump used gears (unless you are buying an entire rear end - like out of a manual TC, which has 3.55's) into things like used clutches and used underwear - I would try not to use them.
Plenty of people have used, used gears. I just would be hesitant to take a chance.
Good luck with the decision.
It took me about 2 hours to pull the old gears and put my (used) 3.55s in, and I changed a few seals while I was there. But I used ford 3.55s if it helps.
