  • 1994 - 1995 Specific Tech
Used Tremec
  • Thread starter Thread starter DocZG
  • Start date Start date Sep 27, 2007
D
DocZG
72
San Antonio, Texas
Sep 27, 2007
  • Sep 27, 2007
hey guys Im looking at picking up a used tremec, because my stock T-5 vibrates in 5th pretty bad going down the highway @ 70. The guy says its a 3350, but i cant find anything on a 3350 anywhere, so Im assuming its just a type o and he really meant 3550. I just wanted to know what all i should ask when looking at buying a used transmission. I know i should ask about mileage, missed shifts, and if it was a race or DD car.
The guy is asking $750 for the trans, BH (appears to be stock), pro 5.0 shifter, and McCloud clutch, does that seem like a good deal assuming its in pretty good shape?
SuperStang83
1,693
Boyertown, Pa
Sep 27, 2007
  • Sep 27, 2007
If it's in good shape and the clutch is still has life left it is a real good deal.
408gt91
114
N.H.
Sep 28, 2007
  • Sep 28, 2007
you sure its your tranny vibrating? did you check the drive shaft,u joints,tire balance,wheel bearings,tranny mount,ect.
Blackened302
1,439
South TX
Sep 28, 2007
  • Sep 28, 2007
that's a really good deal, provided it works fine.
i lucked out w/ mine--got it for $650 w/ the bellhousing, clutch fork, clutch + pressure plate, and a tri-ax shifter.
it's definitely worth looking into!
SuperStang83
1,693
Boyertown, Pa
Sep 28, 2007
  • Sep 28, 2007
Even if your stock tranny is good, I would buy this one provided you have the money. I would take 408's suggestion though and find out where the problem is actually coming from. You might get a new tranny in the car and have the same problem. This is a good deal though, so if you have the money you should get it.
SuperStang83
1,693
Boyertown, Pa
Sep 28, 2007
  • Sep 28, 2007
The only problem that I have heard with the 3550 is the second gear syncros going bad, and not letting you downshift into second.
D
DocZG
72
San Antonio, Texas
Sep 29, 2007
  • Sep 29, 2007
yeah im sure its my tranny, because the vibration is only in 5th gear starting at around 70. I can run it up to about 110 in 4th and have no vibrations, so i know its not the DS. There is also super rough vibrations when i go form 4th to 5th at anything resembling highway speeds. I have recently changed my U Joints and im using an energy suspension mount. My wheel bearings are less than 30k old. Im almost sure its comming from the transmission, the thing has more than 200k on it and it had a U Joint let go at 110, has had a tab break off and was welded back on.... it deserves to go..
I assume there is on way i would be able to check the syncros without the trans in a car?
I am going to check out the transmission this weekend and hopefully pick it up.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
