Hello
I’m looking to purchase a vortech V3 kit for my 89 gt. Motor is stock with 70mm throttle body,shorty headers and high flow h pipe. I have some questions for you guys as i keep reading a bunch of different things. PS, I’m not looking for crazy power gains but something to make it more fun to drive.
With the 5-6 psi kit, will I need any fuel upgrades with the slight modifications that I have on my car? If so, what do you recommend? Do I need bigger fuel pump/injectors/maf? Or since it’s a “complete bolt on” kit, stock fuel system should suffice?
Is it beneficial to add the 8 rib pulley kit to the 5-6 psi kit? I read that it helps with belt slippage.
If I decide to go with the 7-9 psi kit, will it be safe for my stock motor or is that too much boost?
And what is the typical install time for these kits?
Thanks
Scott
Thanks
Scott
