V6 to Windsor swap? Kmember etc...
LX93RiceKill
14
Hi all, I'm considering picking up a 99-04 6cyl Stang, to do a V8 conversion. New to this type of car, though I know the chassis is pretty much the same setup as my 93 5.0 car. I'll be swapping in a 351W. With the fox, unlike the 4cyl, the 6cyl had a diff K member than the V8. It'll be carbed, so that part of the swap is a nobrainer. Will the stock K work with the Windsor, using 94-95 5.0 motor mounts? If not, who makes a K for this swap?
Post this question in the saleen section of this site. Some of the s351 owners will be able to answer your questions.
Remeber that if your going to try to make this street legal then the motor has to be the same year or newer. Also look under the hood theres usealy a sticker that tells you exactly what emissons equipent is required.
