I'm getting rid of the smog/air pump, but where do the two vac. lines go? I see that they both feed into a loom that contains a couple other vac. lines, and then goes into the fender, and somewhere by the intake. What should i do with these? I have to hook the pump back up in two years, but won't it push enough air without the vac lines? I only would need it to pass a test once, so if i have to, i will either rip the lines all the way out, or just block them off on one end. What do you guys recommend?
Lee
Lee
