I just out a 342 with trick flow track heat intake afr 185 areomotive fuel system 48lb injectors holley commander 950 computer and vortech s trim 14lb. Trying to figure out wht im blowing oil everywhere when into boost also the computer system is a dfi system it needs to be tuned but it leaks like a siv . Is there a way of running a vacuum line in front of the blower? Or will i suck oil through the intake? The fuel problem has to do with the tuning if anyone knows how to fix these problems i would greatly appreciate it thanks alot
