vacuum
Beasty306GT
671
Oxford,Mass
so im trying to find the best place to get vacuum for my fuel pressure regulator i have trick flow track heat upper and lower intake...right now its hooked up to the block of plastic vacuum lines on the passanger side behind strut tower...i want to get rid of them..so where would you reccommend to grab vacuum for it..its a trick flow regualtor mounted on my strut tower can i just tee in somewhere..or can i use the capped vac port on the firewall tree thanxs
The firewall tree wouldn't be my first choice. Too much potential for variation when feeding from the same tree that the brake booster uses.
See if you can find something to tee off of that doesn't have such a high demand for Vac.
