If the car is Mass Air and the oil filler vent line runs to a portion of the inlet tract between the MAF and the intake then it [does not matter].
At idle, vacuum will pull air through that tube. That air has already been metered so, it's fine.
During boost, blow-by will be pushed [out] to the same location. Once again, it has already been metered so, it does not matter.
Baffles will help to keep oil out of the intake when blow-by is exiting through the oil filler vent.
This fuel filter thing I see folks talking about is rather new but is not at all necessary. Stick a small oil separator into this position instead or at least use one you can see through in order to know when it get clogged with oil.
