Valve Cover/Oil Baffle Clearance ??Question??
paulfm5.0
Anyone have the thread on how to grind and make 86-93 valve covers clear roller rockers??? The rocker arm nut is up against the oil baffle, curious to see how other guys fixed this without removing the baffle.
  • Sponsors(?)
thebullschmidt
65
if you dont wanna remove the baffle... summit offers a variety of valve cover spacers heres a part number for 1.2in spacer for sbf... STF-63940... hope it helps good luck
Thread starter Similar threads Forum Replies Date
hotdog71 Valve cover oil leak 1996 - 2004 SN95 Mustang -General/Talk- 3
D Engine Oil leaking from Valve Cover Bolt Fox 5.0 Mustang Tech 2
C Engine Valve Cover Oil Fill Tube Fox 5.0 Mustang Tech 0
T Valve Cover Leak - Zero Oil Pressure Fox 5.0 Mustang Tech 14
Chythar Oil Leak on Valve Cover - Ideas on what I should check? 1994 - 1995 Specific Tech 4
SROBERTLAW2003 possible oil blowby valve cover question SN95 4.6L Mustang Tech 5
97GTSTANG Valve Cover Cracked, Oil Leak... SN95 4.6L Mustang Tech 0
97GTSTANG Romeo Valve Cover Oil Filler neck...MISSING SN95 4.6L Mustang Tech 4
88gt373 oil catch can and valve cover question Fox 5.0 Mustang Tech 4
M 4.6l oil pan gasket $19 valve cover gaskets $25 timing chain tensioners *steel* $19 Engine and Power Adder 0
M 4.6l gt oil pan gasket $15 valve cover gaskets $30 /2 Engine and Power Adder Parts 0
S Blocks, heads, Valve covers, oil pans, if you don't see it ask... Engine and Power Adder 13
AdRock Valve cover oil fill neck.... SN95 4.6L Mustang Tech 0
1 oil pan and valve covers for fox Engine and Power Adder 0
82CapriRS help!!!! pushing oil out of valve covers!!! Fox 5.0 Mustang Tech 4
I installing oil filler neck to trick flow valve covers 1994 - 1995 Specific Tech 14
AnthonyR23 Tall Valve Covers - No Oil Filler Cap? Fox 5.0 Mustang Tech 7
Pokageek WHICH valve covers should I get? Me oil bafles hitin the rockers.. 1994 - 1995 Specific Tech 11
T No oil in valve cover? Fox 5.0 Mustang Tech 5
trinity_gt Oil puddling on valve cover near PCV? SN95 4.6L Mustang Tech 22
1 trick flow valve covers..oil fill hole? Fox 5.0 Mustang Tech 9
bdepedro Should I install a baffle in the oil fill hole of my valve covers? Classic Mustang Specific Tech 12
abouttobeglue valve cover oil leak 2005 - 2009 Specific Tech 3
M Anyone drilled a hole for oil cap in Comp Cam valve cover? Fox 5.0 Mustang Tech 0
BlackVert Oil leak: valve cover gasget, questions *DUW* 1994 - 1995 Specific Tech 9
9 i upgraded my oil cooling & pvc / valve cover baffle setup - pretty amazing results Fox 5.0 Mustang Tech 3
C Wierd Problem... Vacuum through Oil Filler on Valve Cover Fox 5.0 Mustang Tech 2
M Oil shooting out of my valve cover breather. 1994 - 1995 Specific Tech 4
fox-gt oil on spark plug / ticking under valve cover Fox 5.0 Mustang Tech 4
5spd GT Blowing smoke/oil out the pcv valve location on valve cover. What is wrong? SN95 4.6L Mustang Tech 16
L Oil Coming out Of Valve Cover? Classic Mustang Specific Tech 9
M Anyway to keep oil splatter off valve cover from pcv area? SN95 4.6L Mustang Tech 5
ADRENLN oil pooling in valve cover? SN95 4.6L Mustang Tech 15
MyEarsHurt WTF? Steeda Oil Cap comes out of valve cover!?!? SN95 4.6L Mustang Tech 5
sveet Valve Cover Oil Leaks? SN95 4.6L Mustang Tech 1
allcarfan valve covers, roller rockers, oiling? Classic Mustang Specific Tech 8
FordStang Venting Valve cover by oil filler?? 1994 - 1995 Specific Tech 5
P Oil seepage from valve cover at bolts SN95 4.6L Mustang Tech 9
BlackFox5.0 Can I hook up my Oil return line to my valve cover temporairly? Fox 5.0 Mustang Tech 2
aj1025 Valve cover leaking oil, what's the dealio. SN95 4.6L Mustang Tech 5
gearhead77 Engine Valve cover/ intake studs and other stuff Fox 5.0 Mustang Tech 5
LIZARDKING Engine Valve Cover Gaskets Fox 5.0 Mustang Tech 1
H Valve cover clearance 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
Bustedknuckle 2.8 after market valve covers / distributors 1974 - 1978 Mustang II Talk & Tech 14
6 Question about valve covers 1965 - 1973 Classic Mustangs -General/Talk- 6
84blkstang Engine What Valve covers fit the trickflow heads and rockers without modification ? Fox 5.0 Mustang Tech 4
D 19641/2 Mustang convertible valve covers need to know what color they should be 1965 - 1973 Classic Mustangs -General/Talk- 15
A Intake manifold to close to valve cover?? 1996 - 2004 SN95 Mustang -General/Talk- 3
James V Fox Valve Cover Issues. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
Justin87 Engine Yet another explorer intake valve cover question Fox 5.0 Mustang Tech 10
