My new valve covers are leaking in the back, "of course, the hardest place to reach" any ways i added a new gasket set from summit, the ones that are rubber with steel inserts. anyways someone told me not to tighten them to tight or it will pull the rubber up to high and it will leak! But they are barely even tight, should i just go ahead and get them good and snug. Also im using washers with the valve cover bolts, is this a good or bad idea? or does it not matter
