Valve covers on backwards???
  • Thread starter Thread starter 88GTMustang
  • Start date Start date Dec 22, 2003
88GTMustang
247
LA california
Dec 22, 2003
  • Dec 22, 2003
On My 88 GT i went to change the oil the other day and I realized that the Oil cap is on the passenger side of the car under the throttle linkage so its impossible to get the cap off without taking the braket that holds the cables on....Is it possible that someone could have put them on backwards? Cuz i know on my 95 V6 that its on the drivers side front
Adam Dugger
584
Long Island, NY
Dec 22, 2003
  • Dec 22, 2003
Um... that makes no sense at all..
unless you have a set of chrome covers designed for the carb'd engine.. the oil filler cap should be in the front pass side... there is no way to mount them upside down.. and if its on the wrong side it will be on the drivers side rear.
pics?
88GTMustang
247
LA california
Dec 22, 2003
  • Dec 22, 2003
Hmmm.... The Oil filler cap is on the pass side rear...Its an EFI and the valve covers I think are just stock and say motorcraft on them, Plus they are RED if that helps any
Adam Dugger
584
Long Island, NY
Dec 22, 2003
  • Dec 22, 2003
stock EFI covers are cast alum, say nothing.. and are grey cast alum.
If yours are metal, stamped alum (square shaped) or plastic.. they are for another small block.
Stock valve covers have a filler tube on them. Find another stang and check em out.
cardudeusa
1,744
Home of the Florida Gators!
Dec 22, 2003
  • Dec 22, 2003
Here this picture might help you. Theres no writing, and the stockers have the little humps in the side.
88GTMustang
247
LA california
Dec 22, 2003
  • Dec 22, 2003
Thanks for the Good help, but i just checked them out a while ago and they say POWERED BY FORD on them so these are probably for some other small block??and they dont have a filler tube just a cap.... And the one on the Drivers Side has the PCV in the front is that correct?? or does it not matter?
xplo89gt
945
Boston, MA
Dec 22, 2003
  • Dec 22, 2003
They are most likely for a carb setup or if they are aftermarket covers, they may have had to be drilled for an oil cap. For instance I have TFS covers and had to drill my own hole for the cap. Maybe the person drilled it and then realized the mistake when trying to put it on.
strtracer442
175
Roseville,MI
Dec 22, 2003
  • Dec 22, 2003
Your valve covers were intended for a carberated motor, not EFI,
The oil fill should be on the passenger front. PCV on an EFI is on the back of the Intake.
Someone bought the wrong covers and used them anyway
88GTMustang
247
LA california
Dec 22, 2003
  • Dec 22, 2003
Could have any of that stuff being in the wrong location have effects on my Motor? Cuz ever since i bought this mustang It smokes pretty bad out of the H-pipe (no mufflers or tails)I think that the valve seals bad or rings are fried, But that was just a thought if any of things are in the wrong location maybe it could causeing the problem????
Black331Stang
1,485
Long Island, NY
Dec 22, 2003
#10
  • Dec 22, 2003
  • #10
hmm..dunno, but either way get some new covers...because u need the connection from the TB to the oil fill tube, plus it just doesnt sound good.
88GTMustang
247
LA california
Dec 22, 2003
#11
  • Dec 22, 2003
  • #11
Still wondering about that???
Also can you explain the connection from the TB to the oil filler tube please!?!?
88GTMustang
247
LA california
Dec 23, 2003
#12
  • Dec 23, 2003
  • #12
Ttt
Mavrick
2,264
Collingwood, ON
Dec 23, 2003
#13
  • Dec 23, 2003
  • #13
The tube that connects from the oil filler neck, to the TB takes fumes from the motor and puts them back into the intake to be burnt off...
I have a set of carb valve covers, but im using them on my EFI motor anyways. You just need to block off the line that goes into the TB.
cardudeusa
1,744
Dec 23, 2003
#14
  • Dec 23, 2003
  • #14
From what ive read that tube allows filtered air to enter the valve covres, the pcv would take fumes from the motor and put them into the inake.
cardudeusa
1,744
Dec 23, 2003
#15
  • Dec 23, 2003
  • #15
anyone wanna clear this up?
Mavrick
2,264
Collingwood, ON
Dec 23, 2003
#16
  • Dec 23, 2003
  • #16
Hmm, I could be wrong.. that is what i have read before.
Maybe someone could set us straight?
YardSpecial
2,664
MT
Dec 23, 2003
#17
  • Dec 23, 2003
  • #17
Yes that is right.
Simply put, U have the wrong valve covers.
Sorry about the bad news.
88GTMustang
247
LA california
Dec 24, 2003
#18
  • Dec 24, 2003
  • #18
any recomendations on what kind of valve covers to buy i dont really need anything expensive or flashy?
88GTMustang
247
LA california
Dec 25, 2003
#19
  • Dec 25, 2003
  • #19
Ttt
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Oct 4, 2026
manicmechanic007
Engine Crankcase vent tube “relocation”?
  • Mcmahst
  • Nov 20, 2025
Fox 5.0 Mustang Tech Dec 20, 2025
manicmechanic007
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
