Valve spring removal
  • Thread starter Thread starter 67coupe351w
  • Start date Start date May 10, 2005
67coupe351w
424
Portland, OR
May 10, 2005
  • May 10, 2005
Hey guys,
Do you all think it would be possible to remove valve springs without a spring compressor? these springs im removing only have a 50 lb force at installed height.
Also, when the sprin is compressed is the lock free to fall out?
Thanks
XXBULLETSXX
301
Kannapolis, NC
May 10, 2005
  • May 10, 2005
I'm no expert, but I think you stand a supstancial chance of bending your valve if you slip? But I think if not having the tool is a problem I think you can borrow one from AutoZone. I know AutoZone is the ricer hang out but they'll hook you up.
latamud
791
Tampa, FL
May 10, 2005
  • May 10, 2005
You can get one faily cheap at Autozone, checkers(yuck) or Napa. There are several kinds and price ranges. I found the "L" shaped one works fine and cheap. Also the large "C" shaped one is great buy pricey. The crappy $6 from checkers works but is a pain.
69Rcode_Mach1
1,473
Salt Lake City, Utah
May 11, 2005
  • May 11, 2005
You will need one to do it otherwise you could damage something and it would be a huge PITA. Also autozone rents the tool for free you just put a refundable deposit on it.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
May 11, 2005
  • May 11, 2005
I'll assume you want to keep all the parts in good shape, so I'll agree with renting or buying a compressor. Believe me, even 25lb lawnmower springs are hard to remove by hand.
If you dont care and just want them off, a piece of 3/4" pipe and a BFH works. put an open pipe end over the stem and keepers and hit it with the hammer. The keepers will fall out or fly somewhere. Wear eye protection.
brianj5600
1,964
Middle TN
May 11, 2005
  • May 11, 2005
Or a deep socket. I've never hurt anything using a hammer and socket.
69Mach351
39
  • May 11, 2005
just rent the tool, or hell, buy one they are cheap, can get one from Autozone for under 10 bucks
krash kendall
1,258
Aldergrove, B.C. Canada
May 11, 2005
  • May 11, 2005
Two pairs of needle nose vise grips.
R
ron67fb
1,117
SF Bay area, CA
May 12, 2005
  • May 12, 2005
Ah, those were the days. Don't forget to put a towel under the valves.
Oh you want to put them back on the head as well? Better get the tool.
krash kendall
1,258
May 12, 2005
#10
  • May 12, 2005
  • #10
Don,t forget to put some rope through the spark plug hole and turn that cylinder up to prevent the valves from dropping into the bottom of the bore, or else its "Off with the head!"
67coupe351w
424
Portland, OR
May 12, 2005
#11
  • May 12, 2005
  • #11
Yeah I just bought the tool, it was only $10.
Except its not going to work as easily as it was designed as this is for workin on the beat of a 22r I was talkin about in a earlier thread
I hope porting and polishing is as easy as the instructsion came with the kit says it is.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Fox Valve Spring Kit PAC-1219X. Help finding needed additional parts.
  • 93gtmustang
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2026
93gtmustang
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
