Valve Spring Retainer keeps breaking
  • Thread starter Thread starter 89StAngerlx
  • Start date Start date Jun 25, 2008
89StAngerlx
  • Jun 25, 2008
I have an 89 Lx notch with a recently rebuilt 306,Crane 1.7 RR and a B303 cam. Now I only have a set of worked E6 heads (they came with the car) because when I rebuilt the motor I couldn't really find a better set. The engine has about 3000 miles on it but in the last 2 weeks has dropped the exhaust valve on cylinder 4 twice. Both times it has been because the retainer has broke which has also thankfully kept the valve from falling all the way into the cylinder. Do any of you have any ideas as to what may be causing this? I had the heads resurfaced, guides replaced and the springs checked to make sure they would work with the cam.
Fast63
717
  • Jun 25, 2008
that's strange dude, did you happen to check the valve guide wear when the heads were off? I'm thinking maybe the exhaust valve is floppin around too much and putting stress on the retainer. Maybe your rocker is coming off the valve and pushing down on the retainer?
89StAngerlx
  • Jun 26, 2008
Well the machine shop replaced the valve guides when I first took them in. When it dropped the valve the first time I didn't even pull the head I just put a new retainer on. That makes sense though. I'll have to check to see if the rocker has been pushing on the retainer. Thanks for the suggestions.
89StAngerlx
  • Jun 26, 2008
I won't be able to check the heads out until later on this evening but what would cause the rocker to be pushing on the retainer? Could it be just a messed up valve guide or is there more to it?
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
5K
Classic Mustang Specific Tech Wednesday at 6:44 PM
DadLife0724
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
C
Engine Can change - valve springs also?
  • Cg’s 347
  • Feb 17, 2024
2K
Fox 5.0 Mustang Tech Feb 22, 2024
2000xp8
Engine Valve and or rocker noise .....new to this but dont mind getting my hands dirty.
  • mustang matt 1993
  • Jun 29, 2024
2K
Fox 5.0 Mustang Tech Jul 1, 2024
rednotch
