Valve springs question
  • Thread starter Thread starter 91ghp5.0
  • Start date Start date May 25, 2006
91ghp5.0
42
Somewhere
May 25, 2006
  • May 25, 2006
I'm running a essentially stock motor with a B-cam. when i order heads, is it necessary to upgrade to larger springs (to accomodate for more lift), or will .500 lift springs be ok? some say i will get valve float, but i want an official answer. thanks!
maverick0716
3,924
Chilliwack, BC, Canada
May 25, 2006
  • May 25, 2006
Valve float is a different issue.....it happens when the springs aren't strong enough to close the valves before they open again. The stock springs will be okay for the B303 as far as lift is concerned, but they may have valve float in the higher rpms.
91ghp5.0
42
Somewhere
May 25, 2006
  • May 25, 2006
alright i gotcha..thanks. i've only ever reved my car above 5k once, and it was the other day. dont plan on doing it again.
thumper460
3,022
Orange Park , Fl
May 26, 2006
  • May 26, 2006
springs are criticle... you know your going to push it a few times.. and it really sux to be having fun and take out an engine for valvesprings!! Cool?? the stock spring will "Carry" the B cam.. shift points at 4500-4800 rpm.. however pushing farther than that your way into the danger zone!! the valve will not only "float" off the top of the cam ramp... it will bounce off the seat and you loose criticle compression... just a thought!! Get the springs!!
Just me...........................
Thumper
Fox Valve Spring Kit PAC-1219X. Help finding needed additional parts.
  • 93gtmustang
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2026
93gtmustang
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
